Need Help!!!
Old Aug 26, 2011 | 07:55 AM
First diesel's Avatar
Oil change time???
Hey guys iam approaching the 3000 mile mark how long can i go before i need to change my oil???? i read the owners manual and it states that it needs 12 quarts of 15 40. can i run mobil 1??? ive run mobil 1 in all my vehicles and have good luck.
Old Aug 26, 2011 | 08:15 AM
fouts's Avatar
I've been changing mine at 5k for oil and 10k oil and fuel filter. Mobil 1 is a good oil and you will get a lot of varied suggestions. I have been using the Delo.
Marc
Old Sep 4, 2011 | 08:05 AM
another oil change question
did the first oil change had to use rotella t6 5 40 synthetic due to lack of options at time of oil change does anbody have any suggestions for a better oil????
Old Sep 4, 2011 | 12:56 PM
Spooler's Avatar
That's a good oil. Nothing wrong with it at all.
Old Dec 5, 2011 | 12:19 AM
Hello back again well got all my deletes done along with a H&S mini max with flo pro 4 inch turbo back exhaust now moving on to leveling kit along with rims and tires getting 20x8.5 black rockstars kinda stuck on tires thought. I work in the oil field in Wyoming so I drive alot in the mud and snow. Any suggestions on a good tire???? I want 35s also with a leveling kit installed would I run into any rubbing issues if I went with a 20x10 rim????? Thanks in advance for everyone's input!!!!!
Old Dec 5, 2011 | 10:43 AM
6.7L MegaCab's Avatar
Wow...let me be the first to say congrats on your deletes. When reading your posts I was wondering if your were going to take the plunge. You will be glad you did!
As far as oil goes, I use AMSOIL DEO 5W-40. It is a bit more expensive, but well worth it. There has been some discussion after doing the deletes that you should be able to run the pre-2007 diesel oil--the CI-4. I plan on doing some oil analysis on my current oil, then switch to the AMSOIL AME 15W-40 CI-4 and performing oil analysis on it as well.
Can't help you on the lift/leveling kit or tires.
Old Dec 5, 2011 | 10:55 AM
Mike Holmen's Avatar
The Guru
I run the same oil in my 2010 as my 2002.
Old Dec 5, 2011 | 07:12 PM
Blake Clark's Avatar
Shell Rotella T standard Dino is what I run. The synthetics are good too, but why mess with what works IMO
Old Mar 1, 2012 | 10:07 AM
On to the next project!!!!
Ok finally got rims and tires on went with 20x9 black ballistic offroad jesters with 33inch federal MTs no leveling kit gonna lift it only want to do it once. Getting ready to move on to an AFE stage 2 cold air intake along with a 100GPH airdog 2. Now Iam going to Powerlabs for the airdog install and the tech there is recommending a fuel rail shim kit along with the install. Does any one have any options on the fuel rail shim kit??? Ive done some research on it and have come up with mixed reviews!!!
Old Mar 1, 2012 | 10:31 AM
About the intake!!! AFE OR S&B??? The S&B is nice to look at and leaner appearance but the AFE just looks like it flows better!!! Any suggestions????
Old Mar 1, 2012 | 06:20 PM
SOhappy's Avatar
Either is fine, just get a dry one. Washing, drying and oiling them is a PITB.
Old Mar 1, 2012 | 07:49 PM
LOWTYD's Avatar
Banks
I've had both the S&B and the AFE stage II. Both are made well and perform as advertised, but After installing the Banks Ram air before I moved out to Arizona, there is no comparison as far as fit, finish and function. The fact that you pick up cold air from outside the engine compartment is worth the price alone. Great investment and I think more filter element than both listed above.
Old Mar 2, 2012 | 01:09 PM
SOhappy's Avatar
... I work in the oil field in Wyoming so I drive alot in the mud and snow. Any suggestions on a good tire???? ...
Hankook ATMs are the BOMB in mud and snow!! (yet quite on the highway and they'll last 40-50k)
Old Mar 15, 2012 | 04:19 AM
getting ready to put on cold air intake and i want to pull the silencer ring out but i am not sure how to do so with out damageing the turbo. has anyone done this on a 6.7 yet??? Ifso i could use some pointers!!!!
Old Mar 15, 2012 | 12:33 PM
hwebb's Avatar
the silencer ring on these arent like the old ones these have to be drilled out one slip and your turbo is done for youll be surprised how much more whistle you get with just the cai
