Leveling Kit
Leveling Kit
OK... Looked at many of the threads here and elsewhere and I'm more confused than when I started! 2015 3500: bone stock. Buddy has 2015 2500. He put Tuff Country leveling kit on his rig. I like how it looks. Doing research on what to put on mine. I like Thuren. Have one of his track bars on my '02. Great piece. My problem is that I've seen lots of posts referring to the 2500 and not so much with the 3500. Also, opinions everywhere from "don't do it" to "go with a full suspension lift" are all over the web. I'll be getting tires/rims in the spring. Not getting silly with the size. Something around 35s or so. So, where do I go with this? Anyone having issues with the Thuren leveling kit? I've read too much stuff and am cofused as hell! Also, will I be able to get the speedo reprogrammed to compensate for the new tire circumference? Help!
Just a plain ole guy
4x4 is easy to level. Don't overthink it. Not really any difference form 2500 to 3500. Kits are available all over for about $100. Takes an hour to install. I had 33's on my 2500 when it was leveled and it was about as big as I could go without rubbing when turning. the dealer can adjust the speedo or there are several controllers like Smarty that you can get to adjust your won.
Plenty of videos on you tube about leveling kits from all the mfg's. Just watch a few and pick one out.
Hell Bent Steel only way to go!!!
When it works flawlessly now (5) 6.7L Ram Trucks later (2011,2011,2014,2015,2018) why change anything? Also their steering stabilization system is absolutely the only option I’d ever recommend. PERIOD!!! However, as free Americans with the right to make our own decisions, if you decide to go with another kit, enjoy that 2nd place trophy!!!
sgtdiesel
25
06-26-2012 02:37 PM
