High Idle???
As I mentioned in a previous thread, I just this week traded in my 08 5500 C&C for a 2012 Laramie 3500 dually. On the 08, the dealership was able to "turn on" high idle. Do the 2012's have this feature?
Joe |
Yes.... Cruise control on, hit the set button and you should be idling around 1100 rpm.
Turns itself off if you put it in gear or touch the brake peddle. |
Originally Posted by unit74
(Post 3091354)
Thanks guys, that is good to know!!
Joe |
That and the remote start are the only reasons I miss my auto....
Do you ground out the green wire by the steering column on a 2010 the same way you would on a 2008 that has the g56 manual transmission
