Full delete with mini maxx and perform service message
Old 04-07-2018, 06:10 PM
staarma's Avatar
I did a full delete last summer using a mini maxx and the trans tune. Recently when I’m towing or when I get on it to pass the perform service message comes on and the message stays until one key cycle. Anyone had this happen? It’s had two services since this problem cropped up so I know I’m not over on miles.
Old 04-09-2018, 12:17 PM
Busboy's Avatar
Did you also do the Crankcase vent delete? I would check the boost pressure/temp sensor on the rear of the intake horn, a single torx screw. There is an updated one available from Cummins for around $45.
Old 04-10-2018, 03:47 PM
staarma's Avatar
Yes I did the crankcase vent mod too. I also used the glacier air horn that replaced the stock with throttle valve. I’ll have to check that sensor. Thanks
Old 09-12-2018, 11:36 AM
tobyw's Avatar
Any updates on this? I've got the same issue with the Perform Service message popping up under medium load/boost situations after the CCV delete. Does the updated pressure/temp sensor tackle this problem, or are they unrelated issues?
Old 10-01-2018, 01:50 PM
Just a plain ole guy
1-2-3's Avatar
It's a 2012. Maybe it's just the built in mileage timer telling you it's due. Have you done a simple reset procedure?
Old 11-02-2018, 05:16 PM
staarma's Avatar
No update here. Just living with it.
Old 05-01-2019, 05:21 PM
staarma's Avatar
Update:
Ok, so along with the CCV reroute you also have to take the filter out of the valve cover and delete the media and reuse the portion that seals against the valve cover. Basically the crankcase pressure sensor was reading out of bounds because of too much pressure in the crank case. Once I deleted this and ran a 3/4" hose from the valve cover to a catch can I mounted on the firewall it hasn't done it again. From the catch can I then used the 90 degree 3/4" hose with a small round filter on it. So far so good under all extremes and no oil in the catch can. I suppose you could just run a hose to the ground like the past 24 valve motors did but I chose a catch can just in case.
millsy
02-03-2013 10:04 PM
folsom_blues
28
04-03-2012 08:54 PM
bggrndodge
01-07-2012 11:03 AM
2006BLKMegacab
01-15-2011 01:33 PM
sharp21
06-20-2010 03:56 PM
Quick Reply: Full delete with mini maxx and perform service message
