Deleting the 6.7: A guide to making it run right! (4th Gen Section) UPDATED 6-6-11
#331
I think I can... I think...
attached is a list specs. The one marked with the red arrow has the best attenuation but the CFM is quite a bit lower than some of the others. Anyone know what CFM we should look for to make these trucks breath properly?
#333
Very nice, every one I've done has been on the floor. Other than the 4500 they all had pretty decent ground clearence though. I wasn't thinking about that cross member. I guess if the muffler won't fit you could short pipe it from the down pipe back far enough to get the muffler in. I would strongly recommend using band clamps instead of the ubolt style clamp. As they do not crimp the pipe and will make disassembly a lot easier if you ever need to take the exhaust apart.
#334
Very nice, every one I've done has been on the floor. Other than the 4500 they all had pretty decent ground clearance though. I wasn't thinking about that cross member. I guess if the muffler won't fit you could short pipe it from the down pipe back far enough to get the muffler in. I would strongly recommend using band clamps instead of the ubolt style clamp. As they do not crimp the pipe and will make disassembly a lot easier if you ever need to take the exhaust apart.
#335
From this link I can assume that our factory intakes will provide 675 CFM. Does anyone know how that would convert to exhaust flow requirements? It's an assumption based on a guess but I would think the exhaust would need to be able to flow more because it's expanded from heat but if this is so how much? Anyone know the answer?
#336
Help 2011 Delete
2011 Laramie 2500 4x4 auto with Smarty Jr.
Replaced exhaust system from the turbo to stock muffler with a delete kit. I did remove the EGR motor actuator.
I still get the following codes:P049C, P242F, P2463, and P1451. I deleted them with the Smarty Jr. but they still come back. The system was showing "Filter full, reduced mode" whem I started the delete project.
How do I solve this problem?
#337
#338
Thanks, but I tried that and it didn't work
#339
#340
Thanks, I have tried it both ways. Unplugged I get all kinds of codes, plugged in I only geet the 4 listed. Maybe this is a smarty version problem.
#341
Are you sure the smarty jr you are using has the software needed for deleting? I have the race me which does have it and I have had no problems. I didn't think the smarty jr was delete capable, only for tuning with all the emission items still in place.
#342
Figured this is the best place for this question. I have spent numerous hours researching all of the DPF and EGR delete posts (most are old) and have yet to see any that answer this question. Is there any way to disable just the EGR and run an EPA Friendly tuner with the DPF left alone?
I am holding off on doing the deletes until after the elections next year. I figure the EPA has done so much in the last 8 years that, if we have 8 more years with another left wing lib, the EPA will be pushing emissions compliant check road blocks. Also, I am not having any issues with the DPF and it will only gain an extra 15 to 20 ponies.
I do however have a huge issue with the EGR. Its like going for a run breathing in partial hot farts? Not sure why anyone would think that an EGR is a good idea. My truck is a 2012 Dodge Dually 3500 and right now I am just running a Smarty JR (EPA version with no deletes)
Can I just do the spring removal and unplug the EGR? I can just clear the Check Engine light code from time to time with the Smarty right? Or will I end up going into Limp Mode? Does anyone just sell the EGR simulator? Let me know your thoughts.
#343
I am not sure what happens when you unplug the egr actuator while running a tuner, but on a stock truck what happens is the computer will throw a "soft" code, but will not throw you into limp mode. It also will derate your horsepower approximately 40 h.p., but you probably won't even notice that.
#344
On a 2010 it would work to unplug the EGR, on a 2012 you cant. Has to be tuned out. Either have to run the ME tunes for smarty (if you dont have one of the newer US serial models that wont allow it from what I hear), use a Raceme OR another tuner that can delete the EGR (many of the EFI tuner companies can write their own tune for you).
I just deleted my DPF/Nox/Cat on my 2012, running the 100ohm sims for now until I can get EGR delete/gauges/tune next year to delete the EGR also.
You could ask some of the tuners to see if they could give you a stock power level tune and delete the EGR but youll still improve fuel economy with a mild tune anyway 40-80, some running the 100-120 get even better if you keep your foot out of it.
