Deleting the 6.7: A guide to making it run right! (4th Gen Section) UPDATED 6-6-11
#151
Blake, before I ask my in-expeienced questions, I too wish to tell you how great your threads are on DTR. Do you have time for anything else with all of us 'newbies' asking for your help??
So I asked you a few months ago if I could run the edge juice on my 2010 with the smarty ME. You said as long as I only changed the timing on one, I will be safe.
Looking at the updated thread tonight, I hope to confirm that what I am about to do will be OK--
Edge juice is on and working fine. Got the smarty JR ME and flo-pro dpf pipe on a shelf, as well as the sinister egr delete kit. The pipe has one round threaded hole in it.. What goes there? I know to cap the rest and wire tie them up, but when I ordred a pipe with no bungs, I was surprised to see one.
The updated thread says I can just have the smarty tell the truck to shut off the EGR, and it is good to go? So after I put the pipe on, I tell it to delete both, then I can go back after I get more confidence in myself and do the EGR stuff at a later time? I have read through all of the instructions for the sinister EGR, and it is..... well, mostly clear...
And lastly, if the EGR is shut off in the computer, what is the functional difference between it being 'shut off' and actually removed. IE mileage, power, egt's etc...
Again, thanks for your work on the forum.
Lemer
Lemer
#153
EddieHaske
Question: I would like to to do the Blake style delete i. e. DPF delete and EGR delete, Full delete, for my 08 Dodge 6.7 cummins, 4x4, longbed, What exactly do I need in parts and tuner minus the gauges at this point?
#154
Lemer
Lemer
Correct. O2 sensors are the larger ones, temp probes are the smaller ones.
Oh, and, Welcome to the DTR!
#155
"Swole It like ya Stole It"
Got my deletes done today as well as my Mini max..
Was just going for a delete pipe and when I opened the box, it was a turbo back.
So we had to install it all. Well just the down pipe and where a normal delete pipe would stop.
My H&S egr and cooler delete kit didn'y have the block off for the cross over tube, so Rich at Dog House had to make me one on the lathe..
It seems to run great! Exhaust sounds a little wierd though.. lol
These vgt turbos with the exhaust break sound funky..
Well at least it's not to lound in the cab. We left the stock resonater on.
Few Pics:
The piece that was missing ::: this one Rich made.
Few Pics:
#156
EddieHaske
Thanks for the welcome Blake, I went ahead and ordered these parts.
H&S EGR/Cooler Delete 2007-2008 Dodge 6.7 HAS-301001 1 aFe Large Bore HD 4" Turbo Back Kit T409-SS Dodge Cummins 6.7L 07.5-10 aFe-49-12009 1 Smarty Junior Tuner 07.5-09 Dodge Cummins 6.7L (DPF Delete) SMA-J67ME 1I think that is everything I need. I also should have mentioned that my reasons for doing this is constant codes and regen and intermittent loss of power. Over the past week I have taken several long trips around AZ and it did fine. Last trip to Phx was fine but when I got back the next day it would barely go down the road until it warmed up, once warm it runs pretty good with only a intermittent hesitation and stutter. I am feeling good about doing this mod to my truck since my after market warranty does not cover anything on the exhaust side of the truck. Thanks again I will let you know how it goes as I will be doing all the work tomorrow.
#157
I finally did my deletes. Everything seems to be going good so far. Had one curious thing though.. With the edge juice, I set my EGT's to 1350, and the turbo to 32 to be safe. Before the deletes, the only backdown I ever got was from EGT's approaching the limit. With the deletes, EGT's are down 100-150 degrees. I hopped on it once to see how it did, and the turbo seems to spool up faster, to where it went into backdown because of the turbo getting up to 32. Does the turbo go higher after deletes are done??
#158
David, looking good.
Time to really go all out on it. Lets say, just shy of Swoled.
It seems as if you have everything in order. Lets us know how it works out.
With the new programming it will spool quicker.
#159
Eddiehaske
Well, I did turbo back exhaust, EGR/EGR cooler delete set up with the smarty before I started it. Smarty Jr. has power on demand settings from 00-99 set mine at 60. I have not got in to torque settings yet until I learn a little more about what Smarty Jr. does.
With the settings and the deletes done I have a Ram that runs and breathes just like a diesel eng. should. It is way more responsive. I still haven't received the intake throttle replacement so I am just taking it easy until I get the part.
Thanks to Blake this job was way easier than I thought it could be.
Thanks to all who have asked questions and replied as I have read all of the delete threads in order to do this job.
I will post more on the how to's that I ran in to.
#160
NAH!! This is about as far this one will go..
I've got my 07 now for the power fix..
Just went to the track on Sunday with Rich for EFI Live tuning.
Did you see the vid??
NO LOCK UP SWITCH YET!
Went from an 8.02 @ 89 down to an 7.67 @ 91 in the 1/8...
http://www.youtube.com/watch?v=otZee...e_gdata_player
#161
LOL
That is impressive. I really like how little smoke its putting out when it launches. EFI Live cant hit the 4th gens fast enough.
Yeah, Im envious. That is sweet!
#162
Rich isn't even through tuning it yet down low.
He says it'll get even better..
Impressive so far though!
Thanks man!
#163
Quick questions for clarification
I'm a newbie here, Just purchased a 2012 RAM 2500 6.7 couple months back.
I intend to do the Programmer ONLY without removing anything Delete.
GOAL = Improve MPG + added benefit of a little perf (HP) gain.
I want to be able to reprogram back to stock without mucking with any hardware for any potential warrantee work, Emmissions I'm not worried about here in WA as I have 5 years before I have to be tested.
So here are my questions:
1) Looking at the MADS site they have both the Smarty j-67 ($495) and the S-67($695), from the thread to do what I want I need the S-67 version am I correct?
i.e. Programe #2 (or 70 HP equavilent setting) on Smarty and disable Emmissions.
(Obviously if you want to monitor EGT you want the Black Maxx (H&S) - still thinking about that one).
2) What is the exact step in programming with the Smarty, i.e. go in and disable emissions, the flash then a second time to set the performance program or will it allow me to do both in the same flash?
3) I presume SOOT will build up in the turbo and other places over time when running in this config, so it would seem that just flipping emmissions on for a day then back every once and a while to burn off any SOOT would do the trick, correct? Any particular interval recommended?
Thanks again
Thanks again
#164
I'm sure somebody will correct me if I'm wrong....
#165
Not sure if that will work. I mean, the programmer will disable the EGR thus providing better mpgs and oil life/engine life. But- the truck won't regen and the DPF will clog up. You should at least plan on removing the DPF and 2nd cat (you can leave the 1st cat in if you don't want to mess with jacking up the tranny). It's my understanding that's an easy install.
