Deletes and EB
Old 11-30-2011, 06:29 AM
chopper698's Avatar
Deletes and EB
I have an 11 with all the deletes should I be using the
exhaust brake to keep the turbo clean?
Old 11-30-2011, 09:33 AM
redlineguy's Avatar
It's a good idea to use it.
Old 12-01-2011, 12:28 AM
tcr
tcr's Avatar
How often should it be used?
Old 12-01-2011, 06:28 AM
MikeyB's Avatar
Tom, use the EB much as possible, except in inclement weather when not towing.
MikeyB
Old 12-01-2011, 08:27 AM
Stargeezer's Avatar
MikeyB
Why not in inclement weather or when not towing? I turn mine on almost ever time I get into the truck. I've been wanting to do the mod that turns it EB on automaticly, but just have not had the time.
Larry
Old 12-01-2011, 10:31 AM
MikeyB's Avatar
Don't want the rear to lock up on slick surfaces when running empty.
MikeyB
Old 12-01-2011, 12:54 PM
redlineguy's Avatar
MikeyB
YES, if in tow mode it can down shift hard and break the tires loose.
Old 12-06-2011, 08:42 PM
Delmar's Avatar
MikeyB
I leave the exhaust brake on all the time, you will not break the rear tires loose on slick roads. It's not that effective.
Old 12-06-2011, 09:09 PM
Brian08Q35004x4's Avatar
Location: This Nazi state of California 2nd home Gilbert AZ under God
I had it hit in tow haul mode on logging road and have me pucker pulling a loaded trailer. You want to be careful on wet, ice or muddy roads in winter loaded or unloaded. That kick down from third to second can make you tighten up.
Old 12-06-2011, 09:11 PM
unit74's Avatar
With deletes and a Smarty Jr ME I found it's not as effective as it was stock. Not sure why though.
Old 12-06-2011, 09:47 PM
RAMRODD's Avatar
When I downshift to 2nd my truck will slide on gravel.
Old 12-06-2011, 10:54 PM
gyman98's Avatar
Something must be wrong with yours, mine is very strong with 15000lbs behind. Need to get a good load on my gooseneck to really try it out. Seems to work with the brake controller somehow and comes on much stronger when the brakes are applied hard
Old 12-07-2011, 04:42 AM
Blake Clark's Avatar
With my 08 it would downshift hard enough (4th to 3rd, and 3rd to 2nd) that it would chirp the back tires on occasion. Not many icy situations in South Louisiana, but I would NOT want to be running that thing in those situations.
Old 12-07-2011, 05:08 AM
redlineguy's Avatar
Mine will and if you get agressive and down shift it hold on even on dry roads.
Old 12-08-2011, 12:07 AM
Delmar's Avatar
The above are all valid reasons for manual transmission being the way to go for a working truck.
I control when and how "hard" my truck down shifts, look at my signature.
GavinS
Introductions / New People
08-31-2014 07:04 AM
howe719
67
12-11-2010 06:51 AM
grush
11-30-2010 12:38 AM
jcmoyer2004
03-12-2010 07:38 PM
Kblake
02-05-2010 12:08 PM
Quick Reply: Deletes and EB
