2011 Mega with Nav- Adding an amp/Subs question
I searched and didn't find what I am looking for. I have an 11 3500 with the Navigation, no entertainment screens.
I am looking to do the JL Megacab box and 1000/1 amp. Does anyone know what adapter I need to get an RCA input signal? I went on PAC's website and it was of little use. I'm looking to do the easiest install possible with minimal wire cutting on the factory harnesses. |
I just put subs in my crewcab under rear seats. I used this harness from pac. PAC AOEM-CHR3. I got mine off Ebay for under $40 installed. It was plug and play and just had to install amp kit and no splicing required. If you have the factory Infinaty system you have to use a different PAC which is little more money.
Mine is the factory Alpine Navigation unit. Any difference?
this guy did a total upgrade. might have some info that will help you in your quest
http://www.ramforumz.com/showthread.php?t=74171 this guy has the alpine nav system and upgraded some parts and added a sub. http://dodgeforum.com/forum/4th-gen-...r-upgrade.html |
