STOCK 6.7L longevity??
What im talking about setting the cruse in park is my truck has an idle up feature not sure if they all do basically the truck is running (idling) you reach over turn on the cruise control then hit the set acc truck then idles up to 1,100 i know its pretty commom on the 3500 automatics not sure about the stick models or 2500's
Nope, My 2010 Laramie Auto has it....it might be run like an ambulance, but that's about it.
Turn on the cruise, bump the stick to set, and it will go to 1100RPM....and you can raise it up to 1500RPM. I use it all the time for jump starting tractors.
Chris
Chris
Back on subject, I know mine is an 09' but heres the dope. 268,000 miles, all stock, maintenance done on time or just a little late. Just had my second DPF full and go into limp mode. Made it 600 miles home at reduced power. Mileage kicks *** empty on reduced power. Cleaned the EGR today, removing the DPF and Nox filter for cleaning tonight. First time for either. I will run this truck until the 13's come out with SCR. Still a good towing truck.
back on subject, i know mine is an 09' but heres the dope. 268,000 miles, all stock, maintenance done on time or just a little late. Just had my second dpf full and go into limp mode. Made it 600 miles home at reduced power. Mileage kicks *** empty on reduced power. Cleaned the egr today, removing the dpf and nox filter for cleaning tonight. First time for either. I will run this truck until the 13's come out with scr. Still a good towing truck.
dont mean to go off subject my truck has 234k on it now. The dealer wanted to clean the egr, turbo, and ccv fliter at 67k. I declined because it was $1000. Now ive done the ccv and its about time again but how or what do you clean on the egr and how do you clean the dpf? My tail pipe soots up like a 5.9 now and some guys claim ive burned thru the dpf because the exhaust pipe should be clean.
There is a stickie on the 3rd gen board on how to clean the egr. The dpf is an experiment, remove and flush with water from back to front. Once the water comes out clear, duct tape a 200mph leaf blower in the same direction and let it run till no more soot or ash comes out. Will re-install tomorrow and let you know how it works. Amazing how much crap came out.
Just a little update, it is all back together. Exhaust is flowing much better and lost the potato in the tailpipe sound. Just need to figure out how to get rid of the Reduced Power Mode.
Hey, aketay did you ever figure out how to get rid of the reduced power mode?Thanks in advance.
Small update, 328,000 miles now. DPF is (has been) toast for long time. Can't tell if it still regens, mileage has been reasonable for as cold as it has been. Smokes like a 5.9 and the power is still there. Had to replace the egr as the spring was too weak to keep it closed.
Still Going Strong
I purchased my 2007, 2500 6.7L / 68RFE new
at 180,000 Km / 111846 miles the entire engine had to be decoked as the entire intake and exhaust was caked in carbon. The truck died on the road.
The dealer stripped down the entire intake and Exhaust system, I saw the evidence.
It would appear the first generation 6.7L used more EGR than the engine could handle.
Once the engine was cleaned I had an after market EGR Delete and DPF Delete performed on the engine.
Currently the engine has 844,000Km / 524436 Miles
I replaced the injectors at 800,000Km 497,095 Miles
I recommend regular oil & filter changes plus fuel filter change at the time of oil change. I also recommend twice yearly Transmission and Differential oil change.
As I run Hot Shot/Courier service my truck lives on the road.
I would like to reach 1,000,000 miles on this truck without having to replace the engine. The Transmission is beginning to slip and the temperatures are beginning to climb after each oil change.
I hotshot cars in Texas. I have 490k on my box stock 2wd 2011 I bought new. The only time it's unhooked from my 50ft trailer is when I take it to change oil. It's an auto with the 68. Not enough blowby to blow the oil cap off when it's upside down. Replaced the egr cooler, a couple of turbos. Transmission was replaced at 400k but it was misdiagnosed. Turned out to be the wiring harness. Had the differential rebuilt about 3 months ago. I wore out 2 5.9s with 6 speeds. I'm now a believer in 6.7s and auto transmissions. BTW, last summer my wife and I took a vacation (rare) to west Texas and driving 70 to 80 mph I got 20 and sometimes 22 mpg.
Winner winner chicken dinner!
Great to see updates, I laugh when I constantly read you must delete, these trucks won't last stock, EGR and DPF is the end of Diesel longevity, blah blah blah.
I love my STOCK 2012, it's the only Dodge I've had for any length of time stock. Keep them coming boys!
Don't get me wrong if you want to delete go for it, but stock trucks can still rack up 100's of thousands of miles if maintained.
