Replacing serpentine belt...any how to's?
Wanting to change the serpentine belt on '15. Any vids out there? Aside from loosening or removing tensioner, are there any tricks or tips? Looks pretty tight getting around the fan.
Thanks
Thanks
No idea if the '15 routing is any different to my '03, but on mine there is no reason to go around the fan. Study the routing carefully and you can pull it out only by releasing the tension on the belt (use a 1/2" drive ratchet - the only tool that is needed) and then pull the belt off the alternator pulley. Then pull the belt out and install the new belt. It is tight around the tensioner, but it will go.
Just a plain ole guy
Snap a pic of it BEFORE you take it off. Make sure you can see the pics well. Take more than one if needed. Remember too, the smooth pulleys ride on the back of the belt and the grooved ride on the inside of the belt.
DodgeDiesel61
01-26-2019 07:45 PM
DodgeDiesel61
0
07-28-2010 11:14 AM
