Rear wheel bearing
Rear wheel bearing
Rear wheel bearing has started making noise again after 3 months changed both bearings and races and oil seal 2016 ram 2500 diesel 4x4
Make sure the fluid level in the diff is at the fill line and not filled to the fill hole. I've heard of overfilling causing foaming and lack of lubrication and seal leaks. Should be 1/2" to 3/4" from bottom of fill hole. I've heard the diff will make some weird noises if overfilled. Dealer says doesn't hurt anything but I don't buy that. My opinion.
silverbullet02
10-05-2009 12:16 PM
Wilbur01
08-03-2009 11:16 PM
ram350013
06-30-2006 03:18 PM
Encryptic
12-18-2004 07:40 PM
