Perform Service: 67,500 mile CCV replacement
Interesting experience, the "Perform Service" message dinged in my EVIC at 67,500 miles. Knew that meant a new CCV filter. I should have had one on hand already, but I thought it would be OK to drive it lightly for a couple of days until the new one arrived. However, my MPGs immediately dropped by 30% and the truck started running funny- less power, not downshifting when it should. I knew there was a potential of oil in the turbo and even a run-away with a clogged filter, but thought it way too much of a coincidence that it actually NEEDED the CCV replaced at EXACTLY the recommended service interval.
Lesson learned: buy a CCV before it's needed. Easy to do yourself by the way, did it in the parking lot at work during lunch, 20 minute job (unless you drop your oil filler cap and it gets stuck between your fan shroud and the radiator like I did, then it's 40 minutes [redface]). I guess the non-DEF trucks also need a DPF cleaning at that point. |
Originally Posted by SOhappy
(Post 3340715)
Originally Posted by johnh
(Post 3340720)
more reason to keep what i have!!!
(Post 3340720)
but they're all great trucks. |
[QUOTE=SOhappy;3341462]Well, you can easily delete the CCV filter if you don't like it. /QUOTE]
Unless things have changed you can't delete the CCV filter on the 2013 and up trucks because of the sensor that is looking for some sort of value of the air coming from the CCV. If you unplug the sensor or remove the sensor but leave it plugged in it throws a code either way. |
[QUOTE=Busboy;3341530]
(Post 3341462)
Unless things have changed you can't delete the CCV filter on the 2013 and up trucks because of the sensor that is looking for some sort of value of the air coming from the CCV. If you unplug the sensor or remove the sensor but leave it plugged in it throws a code either way. Can you gut the CCV and run it to atmosphere and plug the other end at the turbo inlet? Or does the sensor ‘sense’ the change? Curious here. |
[QUOTE=Scotty;3341576]
Originally Posted by Busboy
(Post 3341530)
On my 2012, I tried one of the CCV delete kits that included a plug for the turbo inlet, and a 90-degree elbow and small breather/filter for the CCV port. Every time the truck would see sustained boost above ~15psi, I would get a *ding* and the Perform Service message would come up on the EVIC. I have since replaced the elbow and breather/filter with a 4' section of old heater hose that runs down to the frame near the coil spring (open-ended), and haven't had the *ding* again. So I'm guessing there is some sort of differential pressure sensor that it looks for, and that breather/filter was too restrictive??
thanks for the reply’s
I’m going to leave it as is. |
Originally Posted by Scotty
(Post 3341582)
Originally Posted by busboy
(Post 3341589)
not sure what year of truck you have but my 2011 has had the ccv delete since almost new and never a problem but it doesn't have that sensor.
16’. |
Sorry, I stand corrected. No CCV delete. I was sure I read about it on here somewhere.
