Mods for 2013
Anyone know when or if they will be coming out with some performance mods for 2013. I can't even find a billet gas cap available for 2013. Thanks.
There is no gas cap on the 2013 model, just a flap.
Any billet flaps available?
That was the same when I bought my 2012. (Bought it in Sept 2011). It was at least a year before any aftermarket parts were available.
Anyone know if the gas flaps on 2012 are same as 2013
Originally Posted by gotdiesel7676
(Post 3187019)
Looked at a 2013 in GP a few weeks ago.. The DEF cap is in beside the fuel filler. The fuel filler just has a spring loaded flapper, no cap. That would bother me...
Hi I was at the TDR Cummins Rally in Columbus IN which was hosted by the Cummins Corp. Ram was on hand also they brought a rolling chassis and several 2013 Rams for a ride and drive for us to operate.
The cap less filler tube for the fuel tank has a flapper in the tube which is spring loaded to keep it closed there is also a seal around the filler door to keep dirt out. The reason I think there is no fuel tank cap is the how close the def fill cap is they could interfere with each other so the diesel cap was replace with the cap less system. Rumor has it that Genos garage might offer a rubber cap in the near future to close off the fill tube. It may be harder to mod these newer trucks such as the truck can now sense if there is a fuel filter in the filter housing if not the truck will not start . Another item pointed out was the older ECM had a 76 pin connector where the 2013 trucks ECM has a 96 pin Connector. More diagnostic capability with the newer trucks ECM's so engine modifying may be a thing of the past. Jim W. |
Originally Posted by Jim W
(Post 3188889)
Rumor has it that Genos garage might offer a rubber cap in the near future to close off the fill tube. Jim W.
The fuel door has to be one of the worst ideas on these trucks. I filled mine up for the first time last night and discovered that something about the set up also makes it very, very picky about the angle of the nozzle or else it will cause it to shut off. I had to hold the nozzle through the entire fill up. Not impressed.
I'll definitely be buying a supplemental cap from Geno's or whoever comes out with one to cover the fuel/dirt/water entry port that these trucks come with. Tad |
Originally Posted by TXTad
(Post 3190189)
