4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Rear Differential Fluid
Old 11-18-2017, 04:28 PM
BobWatts's Avatar
I have a 2012 3500 dually and getting ready to replace my rear brake rotors. I expect to lose a small amount of fluid when I pull the axles and I'm not sure weather to top off the fluid with synthetic or non synthetic oil. I'm just sure its going to be 75w-90.
Old 11-19-2017, 06:26 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Always use synthetic oil in HD differentials and when used for towing. Synthetic does not break down under high temperatures.
The following 2 users liked this post by BigIron70:
BobWatts (11-20-2017), NJTman (11-19-2017)
Old 11-19-2017, 09:56 PM
gsbrockman's Avatar
Since RAM started using AAM axles back in 2003, they have all been shipped with GL5 75W90 synthetic.
Old 11-20-2017, 01:50 PM
SOhappy's Avatar
Pardon my lack of dually knowledge, but you have to pull the axles to replace the rotors?
Old 11-20-2017, 02:35 PM
Just a plain ole guy
1-2-3's Avatar
I believe on a 3500 you do. 2500 and below, no.
Here's a random video of it being done on a little older model
Old 11-20-2017, 05:01 PM
BobWatts's Avatar
Yes they need to be removed.Then the hub assembly needs to be pulled off and the rotor has to be unbolted(8 bolts) from the hub.
First time for me
Old 11-21-2017, 05:54 AM
1-2-3's Avatar
It's not a big deal. There's no gear setup involved. Take pics as you go. Keep things in order and clean. Watch the vidja above.
Old 11-23-2017, 10:17 PM
joem's Avatar
Old 12-10-2017, 02:41 PM
SyN
SyN's Avatar
I’m going to drain the FF @ the 15K mile mark & add a Mag Hytech Cover & refill with Red Line 75W-90 & mix in 1qt of RL 75W-140.
Old 02-13-2018, 03:18 PM
chariotdriver's Avatar
Would filling a 2017 3500 chassis cab diffs with 75-140 hurt anything? We have a bunch of it for the old trucks laying around, trying to keep things simple....
Old 02-14-2018, 07:08 PM
C Schomer's Avatar
I think 75/90 is entry level. I use syn 85/140 in all my trucks for heavy towing. That's the only weight that keeps the metal off the magnet, for me. I figure mpg every tank and no decrease form the heavy stuff. Craig
Old 02-18-2018, 09:53 PM
Thanks, I’ll remember the “metal off the magnet” comment for a long time.
4x4not
29
04-09-2008 05:46 PM
gnuesse
09-17-2006 06:48 PM
Iron City
26
09-08-2006 04:59 AM
wilnis
09-17-2004 12:33 PM
BADodge2003
08-06-2003 09:43 PM
Quick Reply: Rear Differential Fluid
