How to fine differential ratio
Where is the paper showing rear end ratio on 2013 Ram 3500? My 2001 has a paper in glove box.
Try the VIN decoder on this web site.
I have used it a few times on trucks where the metal tag located on the rear axle is missing or rusted beyond being able to read it. In a pinch, the jack up the rear axle and spin the tires trick work pretty well. Count drive shaft rotation to tire rotations too get the #. |
VINs don't have the axle ratio coded into them. What a dealer can do is lookup the build sheet using the vin as an index.
(Post 3393511)
Thank you
| All times are GMT -5. The time now is 05:05 AM. |
