greasing front drive shaft
when greasing the front drive shaft do you have to put the main transmission in neutral and the transfer case as well in neutral to get the drive shaft to rotate to be able to get to the zirk fitten . to be able to grease it ?
I just jacked up one front tire. This allows the differential to function and let's you rotate the driveshaft, also spinning that tire in the air.
Originally Posted by mikey59
(Post 3316975)
Good luck |
there was mud in the indent so i couldnt see it . but it took me a while that and its a little cold out. but thanks for all of your help
