Geno's quick drain oil plug
Have had that on my truck for many years with no problems. The only comment that I have is that it does not drain as fast as just removing a drain plug. Not really an issue.
I don't have that one exactly, but I do have a drain valve and hose nipple. I wouldn't do it any other way. No mess, no fuss. The hose nipple ends up about an inch above a gallon oil container so I drain directly into the containers from the last oil change and don't have issues on windy days. I send oil samples to Blackstone Labs, so to keep the nipple clean, I have a rubber nipple cap thingy that pushes on to cover the whole nipple. Pulls right off when oil change time comes.
I have not used that one but have used the finger touch one that genos sells which comes with or without a tube. Used one on my 01 for 350k miles and now the 17 has had one for 40k miles with no issues whatsoever.
Finger touch here too.
Three trucks no issues. My friend services a fleet of diesels and installs them exclusively.
That being said my friend has the quick drain on his '07. Ditto. No issues.
My challenge will be installing the new drain plug with new oil in the pan. Gonna have to be quick with the swap out to keep from loosing any more oil than necessary.
Good question.
Going on a cross country trip this summer. Oil change will need to be performed midway through the trip.
With the controllable drain system in place, all I'll need is 3 gallons of oil, filter and empty oil jugs. No catch pan, cardboard, or spill control devices. I believe it will make Campground oil changes easy and clean.
NC, could you have someone video when you swap the plugs without draining the oil ? We would all like to watch ; ) I mean , its totally possible to do that swap but would be funner just to watch ! We might have to mute the sound though when little kids are around. ; )
Dew.
Dew.
madhat (08-19-2018)
Dew.
Dew.
Administrator/Jarhead
When I'm changing my oil (I have a drain valve as well), I start the first jug, then crack the oil filter loose, just enough for a little air to get in there. Sometimes, not always, a little oil will drain out of the oil filter back into the engine, and it keeps me from having a big mess with the oil filter. A gallon ziploc bag with some paper towels in the bottom over the oil filter when I screw it off keeps everything clean.
I have the Fumoto oil drain plug on both trucks. ones been on the 2000 for 17 years. never a problem with leaking or lever moving. I put one on the 2015 about six months ago.
