dpf 80% full
Ok, explain this to me. According to the lit, "under normal circumstances" there is no notification that the DPF purge is taking place. Other than the EVIC showing the MPG dropping thru the floor, I wouldn't have known either. But then the lit talks about the 80% full message. If it's supposed to purge on it's own why wouldn't it purge on it's own thus facilitating the need for the 80% full message??
There are owners that could go 100K miles without ever getting to 80% and some who can't make it 1000 miles without seeing one.
Old Mopar Aficionado Extraordinaire
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
its the short trips to the post office, grocery store etc that plugs the dpf up fast. looking back on it, i have been doing a lot of those types of trips since doing a remodel on the house. home depot is only 1.8 miles from the house so I need to get it out and stretch its legs now and then to blow it out. did that today picking up 5" preformed stainless exhaust clamps for the deletes.
I have a 2010, 2500 4x4 and use it as a daily driver.
I have almost 32,000 on it and have never gotten the message (Knock on wood )
My driving is mixed city and rush hour highway. Sometimes when i turn off the truck and get out, i can hear a crackling sound, so i assume that the truck in in REGEN when i turn it off.
I towed my 5th wheel through the mountains last July and once I got out there within a few days I got the message and had no idea what was going on. I was miles from a dealer and my display said 70%, then it went out. I was only using my truck for very short distances for the two weeks I was there. About one week later it came on again and this time stated 80% full an again this message went away after a longer haul for groceries.
When I hooked up for the return home as I was pulling out, 90% full came on the display and this time I paid attention to the display and saw that it began to clear and within a few miles it indicated that it was now OK. I really did not see anything in that lousy manual that talked about this and I did not get a proper answer until I got home and spoke to the service manager at my dealer. I have not had a problem since.
I do use additives for my fuel and I think think this may be causing this problem (if it is a problem).
Since then there has been an update flash for a regen called net zero idle. This allows people in the boonies to let their truck idle, after approx 5 minutes the rpms will increase to 900 and a regen process will begin, and continue unitl complete or you exceed 25 mph. This is a much slower regen, but not as slow as trying to get out of the woods with a 100% full message and a derated motor
Next time your in that scenario let the tuck idle after its warmed up and it will reduce the DPF level.
Your fuel additives, unless they contain sulfur, will not effect the DPF.
Also from talking with owners passive regen is very difficult to accomplish. It takes a load that sustains EGT's of 1200+ sustained, which as we know is BIG load. The friends of mine that tow don't notice any change in frequency of regens from empty to towing as the load just isn't there. You may occasionally skip a regen if you pull a long steep mountain pass, but you can't rely on passive all the time when towing.
I can tell that I get the regen often. I drive 23 miles each way to work using mostly highways. When you shut the truck down in the middle of a regen you get thta loud ticking sound from the exhaust. Then when full regens are complete and I'm assuming the DPF is clean I get high numbers on the evic like 19-22mpg readings.
I was also remodeling and traveling back and fourth to home depot sometimes as much three times in one day. It didn't take very long before the message came on even though my truck spends most of it's time on the highway.
I've read that there is no difference between a deleted truck and a heavy loaded stock truck as far as mileage goes.
I also read that Chevy may be developing an all electric regen process that will save even more fuel. But I imagine that will cause other problems...But we'll see.
My week old 2012 just popped up a EVIC message stating my DPF is 80% full. The truck has 375 miles on it of which 200+ miles are 65+ mph highway. I don't idle long, but during warm-up in mornings, for about 10 minutes, it goes to high idle automatically and then I drive off. IMHO, this shouldnt happen with less than 22 hours on the engine. Thoughts?
So I hit the road, and within 2 miles of highway speeds, it was complete. I went another 40 miles due to the fact that I love the way the truck rides and had no where else to be. Ahhh, a boy and his truck. No deletes, fully stock. Thanks for reading.
So less warm up time. Ok. I don't have a long trip to work, so I thought by letting it warm up a bit would be better, but according to the truck and you, I guess not. Thanks spooler!
