4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Discontinued parts
Old 12-21-2015, 01:32 PM
PItts's Avatar
Discontinued parts
New to site, first post! Does anyone have a link or know where to go for discontinued mopar parts? In particular, part number 4429369 pipe plug, that goes into the engine coolant vent port, the one that goes from flex to rigid and into the EGR cooler if you Still have one. Flushing my radiator and lost this plug into the abyss (the dark hole that parts and peices disapear and reappear years later) anyway, called local dealership and that part is discontinued but for $285 dollars I can get the entire flex to rigid pipe that includes this 185 cent pipe plug. Can anyone help with this delima, thanks in advance
Old 12-21-2015, 01:56 PM
sherod's Avatar
I'm not sure of the size of that plug but I really bet that you can find a bung plug with the right thread at any good hardware store. You might have to buy two or three and return the wrong one's. Somebody will chime in I'm sure....
Old 12-21-2015, 01:59 PM
Busboy's Avatar
Welcome to DTR...... I googled Ram 4429369 and a couple of sites said it was discontinued but I also found it on a few more, same part number just used in different applications on the truck. Failing that I'm sure that a good nut and bolt place would have something in stock that would fit. Good luck.
Old 12-21-2015, 06:50 PM
MikeyB's Avatar
I would take some rough measurements and head over to the local ACE Hardware store. Probably can find a brass pipe plug there.
Old 12-22-2015, 10:36 AM
PItts's Avatar
Thanks MickeyB, I went to Ace last Saturday and had no luck with any of the 5 fittings I purchased. Will try tomorrow at our local fastener shop. I did call dodge again, told me to call cummins with the block number and they might be able to send detailed drawings showing parts and specs on the motor build.
Old 12-22-2015, 11:07 AM
pind's Avatar
Chances are, being cummins, it's a STOR fitting.
Go to your closest cummins dealer, give them the engine serial number, and /or part number. They will be able to look it up, including any pn updates. I find pickup dealers are rarely able to do that.
Timmer
09-16-2009 08:45 PM
Fred Swanson
02-09-2009 10:53 PM
Bud Kunz
94
12-17-2007 12:49 AM
Big Rich
08-30-2006 11:26 PM
GregMc
0
11-22-2004 03:49 PM
Quick Reply: Discontinued parts
