Cruise control not working 2011 5500
I have a dpf deleted 2011 ram 5500 with efi live. Cruise control stopped working and do not know exactly when it happened. The truck was bought at an auction driven back and worked the whole way. From there it went to a shop and apparently didn't work on that trip. After that we finally realized it truly didn't work. We found a rear abs sensor issue which we repaired; replaced sensor and wiring. Also replaced the cruise control switch which is located behind the steering wheel not on the front side. As of now we don't have any codes up besides a reverse light burned out code because of LED lights, which was the only one that we didn't install a resistor. Also there are no lights are on the dash. Brake lights all work correctly and parking brake is working correctly as well. I am looking on input for what else to look for or if I should look into the tune to see if the cruise was deleted.
We sent the truck to have the tuner looked at and couldn't find anything. Then we sent to a dealership and they couldnt find any problems and then we sent to a different dealership and they couldn't find anything and just wanted to throw an ECM at it and start there. We declined that and we're thinking of finding an aftermarket cruise control system for it.
Incidentally my cruise indicator light on the dash wouldn’t work either until I changed the switch.
MAC174
01-21-2003 11:54 AM
