AISIN Fluid Change
I am at 30k and it's time to change the fluid. According to the manual, there is no mention of a filter. The schedule says to change the fluid at 30k, 60k, 90k, etc. The pan has a drain plug in it so a drain and fill will be easy. What am I missing here...no filter?
You need to re-read your info.
30k = drain & fill 60k = replace sump filter and fluid 90k = drain & fill 120k = replace sump filter and fluid 150k = drain & fill 180k = replace sump filter and fluid Sump filter part number is 68224232AA Transmission pan gasket part number is 68214914AA. The gasket is reusable a few times, but I would keep one on hand. Save yourself some serious cash and source some Mobil 3309 transmission fluid. It will save you lots over the ASRC fluid. |
Thanks for the info. What you said agrees with that I found out, but not in my owner's manual schedule of service. I am not sure where I am missing it.
Originally Posted by Hexnut
(Post 3353848)
