No Oil in transfer case chain slipping
No fluid in transfer case 2013 org warner 44-47. Automatic transmission fluid is now hi they're both dot 4 automatic transmission fluid. Transfer case chain is Slipping. This is a 2013 6.7 diesel 2500 with a little over 50,000 miles hard to believe the seals went bad and pump the oil from the transfer case to the transmission no oil leaks
cdgsledneck
12-18-2009 02:51 PM
