ABS and Service 4WD light
A few days ago the ABS light and Service 4WD light came on shortly after I started off on my drive to work. They came on again on the same day on my way home from work. Now they haven't come back on again. I noticed when they were on that my cruise control wouldn't work also. This happened briefly back in June after I put different wheels and tires on. They are the same size wheels/tires I had on before. It's happened a few more times since then but went away shortly afterwards. Now its happening more frequently. Also noticed last week on the highway with cruise engaged it just kicked off suddenly, no lights, no "ding" no nothing. Just reengaged the cruise control and no more problems. Any ideas out there about this?
Cummins Guru
You need to pull the code first, if you have a code C2201-FDCM/DTCM INTERNAL, then most likely the Drive train control module is bad..
Mine was doing the same thing, on my way to a 1500 mile trip, the 4wd tried to engage without me turn the ****, long story short, I found out that is was moisture in the control solenoid on the front axle, I looked at it really close, didn't find anything, put die electric grease on terminals of plug, it has been 7 months, and no issue, talk to dealer, they agreed with the answer, and they seen this before, they did the same fix, and problem solved.
2010 2500 6.7 Cummins
<div style="text-align:left;">
</div><div style="text-align:left;"></
I am having the same problem with my 2010 2500 I was just wondering if you ever found a fix thanks
onearizoldman
07-27-2017 07:37 PM
Joey-D
12-12-2011 12:52 PM
sssmaly
07-13-2007 12:57 PM
mr T
02-24-2007 06:42 AM
