2010 Possibly blown motor!
I picked my truck up from the dealer today. The work order says they replaced turbo, charge air cooler,upstream and downstream oxygen sensors,mobile desoot,oil and filter change, update ecm, and clean egr valve. I guess I should be glade everything was covered. But I don't feel like it's dependable anymore. When the warranty gets close to ending this truck will have to go.
BAD ANALOGY MOMENT:
Kinda reminds me of rambunctious puppies. The most frustrating and hard-headed pups sometimes turn out to be the best pooches. Bad / goofy analogy, I know. But the meaning is there.
Maybe this pup will become a great pooch... ???
As crazy as this sounds, I would rather have a failure right out of the gate with a truck than to have it fail later. Early failure means the part was defective when built. It's been replaced and from here on out the truck may be great. If you continue to have failures, then that's when you need to consider getting rid of the truck. Anthony
Tobin
nvr-enuf
04-22-2013 01:38 PM
