4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
2010 6 speed manual
Old 03-02-2010, 06:59 PM
  #31
Diesel997's Avatar
I've been looking at 2500 SLT's for the past few weeks and noticed that all the trucks with a 3.73 or 4.10 axle had a "L". All the trucks with a 3.42 axle had a "1"
Old 03-02-2010, 07:30 PM
  #32
rootercycles's Avatar
been doing price comparison of Ford and Dodge. The Dodge is $6k more expensive for a similar model. Is the Cummins worth that much more? Not sure, but I think both trucks are pretty comparable in value....
Old 03-02-2010, 07:32 PM
  #33
justen920's Avatar
When unloaded is it better to start in L or 1st? I have been stating out in
2nd.
Old 03-02-2010, 09:07 PM
  #34
ripping r's Avatar
2nd.
I always start in 2nd with no load. and L when loaded or towing.
Old 03-03-2010, 07:40 AM
  #35
AH64ID's Avatar
You can't get a 6-speed with 4.10's.
Old 03-13-2010, 10:53 AM
  #36
Ten_Bucks's Avatar
Every G56 equipped truck I've ever seen has a L where the 1 should be on the shift ****. Then again, I don't care for the G56 trans so I don't pay that much attention to it.
Scott
Old 03-13-2010, 06:11 PM
  #37
puffsmokeonya's Avatar
did u guys take the laramie edition or the big horn into play on this discussion?
Old 03-13-2010, 10:53 PM
  #38
ripping r's Avatar
mine is a big horn edition.
Old 03-15-2010, 11:27 AM
  #39
truckin-on's Avatar
2010 Laramie, 3.73 gears, and my shift **** has a "1" on it. FWIW. Running light, you can start in 2nd, then go 4th and 6th, and save a few shifts...
-truckin-on
Old 03-19-2010, 08:55 AM
  #40
Grit Dog's Avatar
That's the best explanation yet. Higher final drives will make more use of first gear as first gear. Lower finals will skip 1st more often.
FWIW, I love having L gear even thought the truck can take off in 2nd with a house hooked to it if needed. Nice for pulling into the garage, 3pt turns etc, stop and go traffic, and of course starting out with a load.
No clutch slip at all, just dump it into slow gear!
So 2010s are no maunal and 4.10's. Drove an 06 like that and while it's not for me, I'm more of a 3.42 and 7th gear person, it was stout!
Old 03-22-2010, 12:37 PM
  #41
AH64ID's Avatar
There is no G56 with 4.10's.. in any year.
I would like 3.73's and a 7 speed, with a 7th of .65, and 6th of .85.. Would be perfect for towing and empty driving.
Old 03-31-2010, 01:24 PM
  #42
robert chilton's Avatar
G56 came with 4.44 or 4.88s in the 5500.
4.10s were available in the 2500 during the first year or two of production.
I have 2 G56 trannies. One low gearing from an 05 (in my 12v) and an 08 G56 in a 5500 and both say 1 not L.
The G56 is definatly a better trans than the old NV5600. Mack trucks shift better. Durability is also not a problem when they are not abused.
I also say it was a parts bin thing for the "L".
Old 04-03-2010, 09:45 AM
  #43
AH64ID's Avatar
In the pickups, not the cab and chassis, there was nothing offered with the G56 lower than 3.73's.
Old 04-16-2010, 09:33 PM
  #44
bariley's Avatar
my friends 94 has L,2,3,4,5,R
nvr-enuf
04-22-2013 01:38 PM
jbjarko
06-26-2010 10:15 PM
HOHN
Big Rigs
27
09-21-2009 07:03 PM
Burkert
21
11-26-2007 07:09 PM
MossyOakGlock
18
09-21-2007 03:42 PM
Quick Reply: 2010 6 speed manual
