4th Gen All Products Sell all of your 4th gen products here. This includes trucks, parts, accessories etc.
Mark this thread as Unsold
Performance & Accessories Bully Dog 40428 - supports deletes
Old 11-20-2016, 08:07 AM
STATELINE's Avatar
Bully Dog GT Plus diesel programmer, this is the Canadian model that SUPPORTS DELETES!!!! It is UNLOCKED and ready to go! Includes a new ECM unlock cable for use with 2013-16 Ram trucks, and a used pyro lead (probe not included)
$800.00 may trade locally (SW Pa) for nice 18-20" tires/wheels or tow mirrors + cash to fit 2015
Product Description This tuner is compatible with 2007.5 to 2015 Duramax, 2007.5 to 2015 Dodge Cummins, 2008 to 2015 Ford Powerstroke. This Bully Dog DPF Delete Tuner features a 2.5inch Color screen. It allows removal of DPF/Cat, EGR and Urea injection. It has Built in gauges and safety features and allows you to precisely tune your engine with HP gains. It also allows you to remove or adjust top speed limiter and recalibrateyour speedometer for use of non stock size tires or gearing. It allows you to enable and diasable factory special features such as High idle, fogs w/highs, seat belt chimes, daytime running lights, etc. Automatic safety back-down Controlled by EGT, Boost, Trans. Temp, and Coolant Temp 2010-2013 Cummins Bully Dog DPF Delete Tuner Tow – 56hp/114tq Performance – 80hp/158tq Extreme – 121hp/250 14-15 Cummins Tow – 40hp/80tq Performance – 70hp/110tq Extreme – 110hp/197tq • 4 on-the-fly settings • 2.5” Color screen • Allows removal of DPF/Cat, EGR & Urea injection • Built in gauges & safety features • Precisely tune engine with HP gains • Remove/Adjust top speed limiter • Speedometer recalibration for use of non-stock size tires or gearing • Enable/Disable factory “special features”: High idle, fogs w/highs, seat belt chimes, daytime running lights, etc. • Automatic safety back-down: Controlled by EGT, Boost, Trans. Temp, and Coolant Temp
STATELINE is offline
Old 12-12-2016, 12:22 AM
STATELINE's Avatar
Just got this updated again, now supports 2016 models and cab & chassis models with the Aisin trans!!
Old 12-26-2016, 11:08 PM
STATELINE's Avatar
Reduced to $700!!!!!
CLeger67
04-07-2008 08:17 AM
chevkiller
16
02-16-2004 01:14 PM
Push Rod
02-08-2003 07:51 PM
Quick Reply: Performance & Accessories Bully Dog 40428 - supports deletes
