4500 / 5500 - Chassis Cab Trucks Talk about your commercial trucks here. We realize there are differences with these compared to the regular pickups, so we have provided a place to discuss the commercial versions only.
Overheating and no cab heat
Old 01-20-2012, 07:30 PM
BULLDOZER370's Avatar
Angry Overheating and no cab heat
ihave a 2008 5500 dodge ram 6.7 that has made me crasy. the temperture gage will go to overheating and then the heater will shut down and I have no heat. Been to dealer 5 times and they said air pockets. been to mech 5 times and he said air pockets. have change water pump, raditor cap, themostate, and bleed air lines serveral times. will run normal for awhile then overheats and no heat in cab. what can I try
Old 01-22-2012, 02:18 PM
lovinCTD59's Avatar
Have you let the truck idle with the radiator cap off untill the thermostat opens? This will take a while...
Old 01-22-2012, 05:39 PM
Have done this also have released air serveral times
Old 01-24-2012, 07:25 PM
bobva's Avatar
I dont have a 6.7 but my 12 valve there is a plug on the head next to the T-STAT. It lets the air out.
With truck parked on ramps or whatever get the front end HIGH pull plug fill RAD till AF comes out hole re plug.
you may have to fill heater core by itself first.
Old 01-24-2012, 07:29 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Most likely your egr cooler is leaking. I have seen several doing this lately, it causes air pocket and engine overheat condition. Pull the egr cross over tube and take a look if egr and cooler are clean no soot. It will look like it was steam cleaned, then cooler is leaking. Put pressure tester on and you will see egr cooler to start filling with coolant. I just changed one on 5500 last week, owner said truck never ran so good. Tell dealer Reference Star case Number: S1118000061 has the info he needs to check.
Old 01-24-2012, 07:48 PM
SpeedyWS6's Avatar
Hopefully it is the egr cooler and not the head gasket.
Old 01-24-2012, 08:12 PM
We have raised the truck up and released air several times. still same problems. the egr has been disconnected and removed. still same problem. head gasket is next step i guess.
Old 01-24-2012, 11:02 PM
Cummins Guru
BigIron70's Avatar
OK the egr has been removed but did you remove the EGR cooler also? If not then you could still be getting exhaust gases into the cooling system.
Old 08-27-2012, 02:42 PM
quadstar's Avatar
over heating
Did anyone ever figure out what was wrong with this truck? My truck is doing something similar, I was hoping to find someplace to start looking for problems...
Old 01-04-2014, 04:01 AM
Diesel pipeline's Avatar
Yes I would like to know what it was. I'm having same problems. Has it been fixed?
Old 02-15-2014, 05:28 PM
Girolomo Pace's Avatar
i have the same problems 08 2500 4x4 smarty jr chip airintake 5"exhaust turbo back. I've changed two thermostats water pump done all sorts of head gasket test and it fine i did EGR delete i don't know what to do either
Old 02-17-2014, 06:38 PM
Thats great and all but i have the same problems and i did egr delete
Old 03-08-2014, 06:44 PM
hello bulldozer did u ever fix ur truck
tswcoaltrain
11-12-2019 09:11 PM
bkrukow
04-29-2011 06:42 PM
Charlee
01-10-2005 11:45 AM
crossy
12-05-2002 10:42 AM
crossy
11-01-2002 05:16 AM
Quick Reply: Overheating and no cab heat
