Need a heavy duty cab and chassis...don't know where to start
RV's are exempt including race trailers and some states RV use includes boat trailers. In most states the DOT's are not interested in non-commercial over 10,000 use. Farmers are also exempt within 150 miles of any farm land they farm. Many states exempt farmers from most DOT laws. In KY they don't require tags or inspections on trailers as long as you stay in state. In Va. farm use is the golden pass to almost anything you can pull down a highway as long as all the pieces stay together and you don't have an accident.
Hate to say it but if you need 4X4 then a F-550 Ford would be about the best. With the extra payload package you can get a GVW of 19,000 and a GCVW of 33,000, that is the highest out of any of them. A Chevy 5500 4X4 can go up to 19,500 GVW but only a 26,000 GCVW same as Dodge and Sterling. That is my biggest complaint with Dodge is a GCVW of only 26,000 is nothing. Also having a GCVW of over 26,000 doesn't mean you need a CDL, if your trailer is rated over 10,000 then you need a CDL regarless. I feel they keep it low to help from having all the problems Ford has with rating a truck in this category so high.
I am a true dodge man but Ford has the better trucks in the 450 and 550 range the 450 has 33,000 gcwr,24,500 5th wheel towing,16,000 convenentional towing,14,500 gvwr, 6,120 payload. dodge doesn't get close also you can go to a 650 and get it with a cummins
Right...... That's why Dodge has the best selling C&C trucks on the market right now? They have out sold the Ford C&C for two months now by 100-142 trucks.
the requirements vary from state to state. I reside in two states, New Mexico and California. A 14,000lb trailer in new mexico, texas, arizoa with a combined weight under 26,200 lbs is totally legal.
in California it is illegal to pull a commercial trailer (if you put a tool in it it is commercial) utility, dump, equipment haulers etc requires a class A license. not a class B unless it is agriculture.
i am stuck in california with my track loader and dump trailer because unknowingly i pulled them from NM to CA and i don't have a class A license.
check with the motor vehicle departments in the states you travel in.
My next truck will be a 4500 C&C anyways despite the lower ratings, just waiting for the new bodystyle to come out.
Oh and I think this set up on a Sterling is bit more than 26k by quite a bit
http://www.truckpaper.com/listings/d...FE4578364711B3
Need a heavier duty truck
IF your trialer weight is over 10,000 lbs you have to have a class 1 lisence.Check with the DOt on what your vehicle weight is when you go to a class 3. You might find it easier just getting in and out of some of the places with a smaller tractor trailer unit then a with one that will carry all of what you need for a job even a secand trailer for the job might be easier and cheaper to insure?. One or two of your crew then would need to have a class 1 licence for that kind of weight? Maybe even a larger class 3 truck that will do what you need?
You Guys are wrong. under 26k it doesnt matter what the trailer rating is. As long as the truck and trailer tags have GVWR totaling under 26k, I pulled at 48ft Appalachian with my 3500 and came in at 25,500. Also the GCVWR means nothing. And has nothing to do with laws. its an insurance rating thing. A truck with 19k GWVR can tow more than 7k.
Ok and before all you know it all non CDl guys chime in about the 10k which pertains Class B trucks. and really nothing else. hence a 33k truck can tow up to 10k trailer after that its an CDL A.
So if I borrow my buddies Explorer and use this trailer http://www.trailersforless.com/pj_6_...carhauler.html with a 10,400 GVWR I can get my CDL A with air brake restriction? Even though I am at probably at 18k GVCWR.
Dont listen to anyone that tells you that 10k law needs a CDL A. Learn the laws.
