lamp out and leds
lamp out and leds
bed is finally installed. i have leds and the i now have the lamp out code. i thought that was corrected in the 11's. I believe i need to wire in 3- 6ohm 50 watt resistors to remedy this. Am i correct in this thinking?
Will i cause any damage running this way for a few days until i can do the fix?
truck is an 2011 ram 3500 c&c thanks for any and all responses
With age comes the cage
The rule of thumb on these are you need a minimum of two amps (a normal Non-LED bulb) and a maximum of 4 (two Non-LED bulbs)..
You need to go to the website of your LED company and found out the ampacity of the LEDs that you are using..
Here is a link to the resistors (at the bottom of the link):
http://www.superbrightleds.com/cgi-b...rake-turn.html
I had enough clearance/tail lights on my set up all I had to do was install the one in for the blinkers..
Here is my set up (post 22):
https://www.dieseltruckresource.com/...t213006p2.html
And the resistor install:
Hoss
21
12-03-2016 02:49 PM
carid
07-12-2014 05:42 PM
Asher
02-15-2009 10:27 AM
Pickle
03-26-2005 11:57 PM
