Wind noise @ doors. (easy fix)
Old Jun 9, 2008 | 12:17 AM
-sean-'s Avatar
Lightbulb Wind noise @ doors. (easy fix)
Wind noise coming from around the doors specially in a cross wind situations. Sound familiar?
There have been a few threads about this already and they don't seem to end up with any resolution to the issue.
I've read all kinds of fixes to this problem but one stood out and I thought I would give it a shot, what the hell its free and easy.
First I took the Dodge to the dealer. They replaced the door seals on both doors and said they couldn't promise the issue would be fixed with that and that they would not adjust the doors since they "appeared" to be fine. And get this... "its an inherent problem do to the design of the cab".
OK, so they were right. There was no real change.
So here is what I did and hopefully it will help some of you too.
Adjust the door strikers. Two torx bolts each. Loosen them slightly and tap them in just a little. I moved both of mine in 1/8" and there was no noticeable difference in the door alignment. Then re-tighten them.
That was it, problem solved. NO wind noise at all. Since I've done this I have driven with very heavy cross winds (40mph plus) coming from both sides (no, not at the same time) and the noise is gone.
Old Jun 9, 2008 | 12:57 AM
Tedonlin150's Avatar
Sounds like a good idea. I'll have to try it tomorow...
Old Jun 9, 2008 | 06:57 AM
rbox's Avatar
I have bad wind noise as well on the drivers side. I will try this today...
Old Jun 9, 2008 | 08:04 AM
Toto's Avatar
Thanx Sean
Old Jun 9, 2008 | 09:39 AM
LongRanger's Avatar
Are your doors much harder to close? Thanks.
Old Jun 9, 2008 | 10:28 AM
TonyB's Avatar
That would be my only concern as well.
Tony
Old Jun 9, 2008 | 11:20 AM
jjoiner's Avatar
I just adjusted mine and the only thing is watch for are the body lines. The front door and back door won't be flush if you move the striker too much. No the doors aren't any harder to close.
Old Jun 9, 2008 | 11:31 AM
Azzy's Avatar
What if you have window vent visors?
Old Jun 9, 2008 | 11:36 AM
tauberson's Avatar
Forgive me for the dumb question, but what are door strikers?
Old Jun 9, 2008 | 11:45 AM
paroxysym's Avatar
ill be doing mine soon... driving at 65+ mph I hear a howling sound from my doors, goes away when the windows down. so im thinking its my door seals since they are pieces of sh--
Old Jun 9, 2008 | 11:47 AM
jjoiner's Avatar
Window vent visors will not be affected in any way. The door striker is the piece that holds the door closed. Its the 'U' shaped piece on the B pillar. Here is a pic; http://sugarautomotive.com/doorstriker1.jpg
-sean-'s Avatar
No, not at all.
Old Jun 9, 2008 | 05:02 PM
armourbl's Avatar
I need more description on how you moved them. You said tap them in a little?
ben
Old Jun 9, 2008 | 06:59 PM
hivoltage's Avatar
I done this to mine awhile back and there was no difference in wind noise at all.
Old Jun 9, 2008 | 09:22 PM
madhat's Avatar
Administrator/Jarhead
Did it to my ol's truck. Little taps first... Tap it too hard, you might not get the door back open...
