where to find an 06 dodge fuse panel diagram?
need to find a diagram of which fuse does what in my 06 dodge 3500 4x4 fuse box. cant find anything about it in my owners manual and inside the fuse boxes lid just shows a diagram numbering the fueses from 1 to 42 but doesnt show what each fuse does. anyone have a list of what each fuse powers?? thanks
I looked at the entire index and every page and there is nothing in the owners manual. under fuses in the index it just says some crap like ," your truck is equipped with an eipm "or something like that and says nothing at all about fuses.
From: Columbia in the Communist State of Chicago (Illinois)
owners manual page 420
Hope this post okay. If not look in your owners manual on page 420
1 20 Amp Yellow Power Outlet Console
2 20 Amp Yellow CCN Door Locks/BTSI
3 20 Amp Yellow Spare
4 20 Amp Yellow Spare
5 20 Amp Yellow Power Sunroof
6 10 Amp Red OCM/VIST Fan/Wastegate
7 15 Amp Blue Reverse Lockout Solenoid Battery (SRT-10 Only)
8 10 Amp Red Heated Mirrors
9 30 Amp PinkOff Road ModulePower
10 5 Amp Orange Trx-Off Rd Pkg Sen (Gas Engine Only)
11 20 Amp Yellow IOD-CNN/Radio/ Under Hood Lamp/WCM/SDARS/HFM
12 30 Amp Pink Electric Brake
13 25 Amp Natural Power-Battery RWAL/ABS Module Feed
14 15 Amp BluePark Lamps Left
15 20 Amp Yellow Trailer Park Lamps
16 15 Amp Blue Park Lamps Right
17 15 Amp Blue Spare
18 40 Amp Green ABS Pump
19 30 Amp Pink Trailer Tow
20 10 Amp RedORC2
21 10 Amp Red ORC Preset Carrier
22 2 Amp Gray IGN Switch Feed
23 10 Amp RedECM/WCM/HVC
24 20 Amp Blue Subwoofer Amplifier (SRT-10 Only)
25 10 Amp Red Power Mirror
26 20 Amp Yellow Brake Switch/ CHMSL/Stop Lamp
27 40 Amp Green Power Seats
28 10 Amp RedPower Run/Start-CC/WCM/ABS/RWAL
29 10 Amp Red Switches/EC Mirror/ Smart Bar
30 15 AmpBlue Spare
31 10 Amp Red PCM/Transfer Case Brake
32 10 Amp Red HVAC/Ajustable Pedals/Heated SeatsSwitch LED/ExhaustBrake
33 10 Amp Red Power-IGN Run Misc
34 10 Amp Red Spare
35 15 Amp Blue CNN Illumination
36 25 Amp Natural Audio_Amplifier
37 15 Amp Blue Spare
38 20 Amp Yellow Power Outlet IP
39 10 Amp Red Sunroof/Seatbelt Tensioner
40 20 Amp Yellow Cigar Lighter
41 25 Amp NaturalSpare
42 30 Amp Pink Diesel PCM (DieselOnly)
20 10 Amp RedORC2
30 15 AmpBlue Spare
34 10 Amp Red Spare
where to get owners manual.
If you are needing a full owners manual you can download one just like I did for your truck at this link.
http://www.dodge.com/en/owners/manua...02500%20Diesel
2007 2500 Fuse Panel
this is along the same lines as the topic, I want to hook up an aux fuel tank and possibly other equipment using the key on feature. I know there is at least one spare (using a meter) that goes hot when key is on. removing the fuse panel cover, and then removing the screws for the fuse panel, I can't get the panel to lift out. Am I approaching this wrong. I see all the spare fuse locations and would rather use the existing spares instead of wiring in another fuse panel. Can I do it this way? What have the other members been doing to remedy this problem?
thanks for any help
Al
thanks for any help
Al
On a similar mater, where is the power module, or relay panal. In addition, who has a more accurate electrical schematic, Motor or Chilton or Haynes. To bad a spare aux. power section is not provided, integrated with the factory wireing (fuse panel). My suggestion is to use the aftermarket fuse panel, with a breaker and power relay feeding the new fuse panel. Just make sure your Alternator is adaquate. Excessive power drain will be hard on the factory circuits.
Last edited by InMrFixIt; Sep 25, 2011 at 05:05 PM. Reason: more questions and answers
The96RedBeast
0
Aug 13, 2007 06:55 PM
