-   3rd Generation Ram - Non Drivetrain - All Years (https://www.dieseltruckresource.com/forums/3rd-generation-ram-non-drivetrain-all-years-101/)
-   -   Water leaking into cab under glovebox (https://www.dieseltruckresource.com/forums/3rd-generation-ram-non-drivetrain-all-years-101/water-leaking-into-cab-under-glovebox-165532/)
wlew Aug 19, 2007 11:31 PM
I recently noticed water is leaking into my cab from under the glovebox. It's an intermitant drip. Before it start dripping, I can hear a sloshing sound from under the dash when going around turn or curves.
Initially, i thought it was the AC freezing problem, but the dripping occurs even when the AC is off. Although most of time it happens when the AC is on. Any suggestions?
By the way, I have a 2003 quad cab std output.
Thanks,
Wilson
53 willys Aug 20, 2007 12:18 AM
is the drain pluged for the A/C evaporator catch pan????
Caspter Aug 20, 2007 08:39 PM
I would have to agree with 53 willys on this one. I would try to find the hose and unplug it or take it to a a/c shop and they can tell you where it is or just fix it as well...
crobtex Aug 20, 2007 09:01 PM
I don't know about the 3rd gen's, but mine was caused by the drain hose throught the fire wall. It didn't seem to be stopped up, but after adding a 90* piece of hose on it, it quite wetting the floor. Some folks said it was not letting the water drain due to wind turbulance under the hood.
wiskeyVI Aug 20, 2007 10:05 PM
I was told by the dealership it was do to some bad seals in the AC/firewall.
We had a lease trk on site that filled up on the left side when it rained heavy.
Mark Hodowanec Aug 21, 2007 05:33 AM
Thanks,
Wilson
Water leaks are a pain. I had a leak thru the instrument panel dripping down on the clutch pedal. Took a year to solve. They replaced the cowl seal, cab light seals, etc. Eventually the door seal was replaced & solved the problem.
labreck Aug 27, 2007 12:18 AM
I had the same problem. theres a fresh air intake duct under the couling on the passinger side. remove the couling and there is a large patch of foul tape that covers a hole, remove the foul, and inside the hole theres a plastic tube that comes through the firewall, just seel around the duct where it comes through the firewall. I hope thats clear as mud
