under bed aux tank????
Old Jul 26, 2012 | 01:44 PM
guzzirider's Avatar
I want to put an additional fuel tank under my bed. with a pump that I can switch on to transfer fuel to my stock tank. I had ford PU in the 70s & 80's that had duel tanks. I don't want to pay 41300 for a titan and have all that weight on one siode of the truck.
Anybody done this????
Could I get a used one and install it on the other side of the truck??
Old Jul 26, 2012 | 04:08 PM
rockcrawler304's Avatar
Are you wanting to get a used factory tank to mount on the other side? I would think it is possible if there is room but I bet the exhaust will be your biggest problem.
Old Jul 26, 2012 | 08:48 PM
cLAYH's Avatar
On my 1st gen Cummins I installed a 2nd tank from a Ramcharger that went where the spare tire is. It was pretty easy as a 1st gen truck's frame is similar to a Ramcharger.
I'm guessing that if you can fab up some cross-members it wouldn't be too hard to put in a tank from a Ramcharger. Or even a Blazer/Bronco or anything else that had a tank behind the axle.
Wiring/plumbing it so that it works just like a second tank is much nicer than having it pump into the main tank and isn't all that much more work.
Old Jul 26, 2012 | 08:51 PM
Fordzilla's Avatar
Whatever you use, make sure it's rated for diesel (not galvanized)......Ben
Old Jul 31, 2012 | 10:30 AM
Mongo7011's Avatar
Talk to http://www.aerotanks.com/. They can custom make what you need. I plan to do something along the same lines...
PRO-NRA
16
Apr 1, 2008 12:13 PM
groran
Mar 19, 2007 07:44 PM
Mike T.
Jul 9, 2006 07:31 PM
Turbo Boy
59
Sep 24, 2005 06:44 PM
2500CTD
Feb 27, 2005 01:29 AM
