u-joints replaced today!
Old May 22, 2006 | 10:33 AM
rjm022's Avatar
i called up a well known/established machine shop/drive line shop late last week that has been around for 35 years. it is a 60 mile round trip from my house. i told them i needed both u-joints replaced on my drive shaft. (back one was shot!) they told me to be there first this today (monday). i get there and the guy behind the counter asks me where is my drive shaft . i told him on my truck. he then told me we know longer do them on the vehicle-you bring in the drive shaft. i told him i did not know store policy changed and the gentleman i spoke to on the phone did not mention anything to me either. he told me to hold on. the manager comes out and tells me to pull around back. his tech came out and dropped my drive shaft in the parking lot- he installed two spicer greasable u-joints and had me on my way in an hour. the bill- they only charged me 62.00 bucks!!! i threw the guy twenty bucks for having to lay on the cold damp ashpalt! i think i made out pretty **** good!
Old May 22, 2006 | 11:29 AM
nirion's Avatar
I would say so. Even with my 7/70 warranty I paid the $100 deductible for my 2 rear ones.
Nick
Old May 22, 2006 | 04:50 PM
rjm022's Avatar
i decided to have it done at a drive line shop- knowing better parts would be used (spicer greasable)- i assumed with the parts and labor it would cost me around 50.00 bucks or so more than going to the dealership and paying the 100.00 deductable for the same oem crap parts. but i came out 38.00 bucks ahead!
Old May 22, 2006 | 07:00 PM
coobie's Avatar
Get ready to replace the front u-joints also,mine had ZERO grease in them.I had the front and rears replaced at 35,750 miles on my 2004.coobie
Old May 22, 2006 | 07:46 PM
RDM16CTD's Avatar
Showing my ignorance here, but can the U Joints be replaced with after markets parts, where it's easy to lube them? What is the advantage in building the truck with joints that can't be greased - just a cost savings move by DC?
Old May 22, 2006 | 08:23 PM
rjm022's Avatar
rdm16ctd- when you are ready to replace. use spicer u-joints. the greasable version!
Old May 22, 2006 | 08:33 PM
coobie's Avatar
I used the (48re auto tranny)percision (greasable)295 rear and 464 front left and right.The anwser to your question about non-greaseable u-joints,its all about money.I have a good buddy and neighbor who is a product design eng.for crysler here at the proving grounds located in Michigan.Its all about cutting cost according to him.coobie
Old May 22, 2006 | 09:08 PM
lt11le's Avatar
I do belive I read somewhere that greasable u- joint's aren't as strong as non-greasable ones because the hole that is drilled threw it for the zirk fitting.
Also I think the stock joints are spicer.
Old May 22, 2006 | 09:59 PM
torquefan's Avatar
I always do my best to replace u-joints with Spicer NON-greasable joints. In my opinion they last a lot longer than greasable joints because they have a good, positive seal on the cups. Greasable joints can't seal up as well because they need to have a looser seal to let grease escape.
Old May 22, 2006 | 10:46 PM
Badd Dogg Guy19's Avatar
This is true, but they make greasable U-joints where the zerk fiting screws to the face of one of the caps, instead of on the main U-joint. I put a set of these in My IROC, and have done many of 3,000 RPM launches with zero wheel spin, and never broke a joint yet in like 7 yrs.
Old May 23, 2006 | 04:17 AM
TexasCTD's Avatar
What are some of the signs to know if you have a U-Joint going out? Do they start making a noise?
Old May 23, 2006 | 08:11 AM
lt11le's Avatar
look at the joint caps and usually you will see rust coming out of the seal area when their shot or sometimes vibrations or some noise come from them.
Old May 23, 2006 | 10:23 AM
Nuttymopar's Avatar
The noise my rear one was making at 30,000 miles was a slight squeak, squeak, squeak when backing up slowly. If I placed it in 'N' and let it coast backwards after hearing that noise, the noise would stop as there wouldn't be a load on the u-joint.
Old May 23, 2006 | 04:26 PM
Luken's Avatar
The stock U joints are absolute junk...I would never go to Dodge and get them replaced. Its going to happen again. At a local shop here my dad and I got them for 12 bucks a piece(greasable). His rears went out before 30,000 miles and the new ones have lasted 50,000+ plus....
VFDFireman
Jan 11, 2008 11:41 AM
HappyGA
Jul 25, 2006 08:11 PM
deezulsmoke
Apr 5, 2006 07:14 PM
appaloosa
21
Mar 20, 2006 07:33 AM
