Tire ?? BFG KO's & Nitto Terra Grapplers
Trying to decide what tire to buy. The 2 I'm interested in are the 315/70/17 BFG and the 295/70/17 Nitto.
I'm curious of the weight of both tires and true height. I see where the Grappler is: LT295/70R17 123R 200-430 16.5 Height 33.19 Width 12.13 8.0-(8.5)-9.5 3195@65 626 The 315 KO's I can't find any spec.'s?? Can someone give the KO #'s with weight included on both tires? Thanks. |
This is specs off of BFG Website: http://www.bfgoodrichtires.com/specs...t-a-ko/44.html
Tire Size - LT315/70R17/D Service Description - 121R Sidewall - BSW MSPN - 54142 Rim Width Range (inches) - 8.5 - 10 Section Width on Measuring Rim Width - 12 on 8.5 Overall Diameter - 34.5 Tread Depth (in/32nds) - 17 Revs/Mile at 45 mph - 601 Max Load (lbs@psi) - 3195@50 Original Equipment - GM My BFG 315/70R/17s mounted on Dodge chrome clad steel wheels weighed around 105lbs. The tires alone weigh around 63-65lbs. Don't know about the Nittos |
Thanks for the info.. Where are you getting the weight from? Or is that a UPS weight? Anybody else possible know the weight of the Nitto?
Originally Posted by simoniz
(Post 1235251)
