Daytime running lights on 2006 Ram 2500
I just moved to Canada and my truck needs to have daytime running lights. I took it in to the local dealer and the said they tried turning them on but "found TIPM does not support function". Then I come on here and all the information seems to suggest that it definitely can be done. So what gives? Is the internet lying? Is my local dealer filled with know-it-all dummys? Or do I have the 1 POS truck that just can't be done?
The lights must come on automatically without manually turning them on. I did come across a few older threads on the subject, but I think the scanning tools have changed since then.
Do that Canadian laws dictate that the DRL must be incorporated into the headlights? If not, why can't you go to Canadian Tire or similar and buy a couple of small LED's and mount them somewhere on the front of the truck or even inside the grill? Connect them via a relay to any wire that is hot when the ignition switch is in the ON position.
Simple eh?
Simple eh?
I'm sure I could do a lot of things, but my preferred method would be a factory setting. Mainly because if ever I wanted the lights off while the truck is running, a simple click on the emergency brake and they're off. Plus I don't want to start adding a bunch of stuff ($$$) I don't don't need.
Simple eh?
Simple eh?
My guess is that they will have nothing to say. If his truck was not specifically built for the Canadian market, then why would it be necessary to add the DRL option if the truck was destined for a country that does not have the DRL requirement?
A couple of small LED's and a relay is not $$$, but at most $$ and maybe even only $. Add a hidden switch to turn them off when you do not want them on.
Back to morning brew . . .
Thanks for all the suggestions folks. I finally got it figured out. For anyone else in the same situation, be persistent. I found another dealer about an hour away that said they were pretty **** sure they could do it. Brought it in, the tech hooked up the new computer (witech) and it said the vehicle could not have the DRLs turned on. He went back to the toolbox and pulled out the older scan tool (starscan). Within 10 minutes he had them working just as they should. It would have taken even less time if the touch screen on the tool was working properly. So there you have it... one dealer says no way, can't be done and another one tries a couple different things and gets it done.
BuckyKatt
02-08-2013 01:12 PM
getrdun
11-26-2008 11:46 AM
johmur
09-06-2007 11:23 AM
CNYRAM
23
04-20-2004 07:09 PM
