Stereo gurus need your help
Ok guys so I got a guy that has a AVIC-N2 and a AVIC-N3 thats new that he may tade for some quad parts I have. My question is, to use the navigation features for this, can you utilize the stock Sirius antena or how does it work? Would I need anything special to make it install into my truck?
Link
Also what is the differance in the two units?
Link
I'm not sure about the difference between the two.
And yes, there are some things you will need to make it work. Firstly a canbus adapter to wire it in, as the factory stereo uses this instead of traditionally labeled wires (speed senor, dimmer, illumination, switched power, etc). Second, if you want to have proper fade and balance controls, you will need to by-pass the factory amp (if you have the infinity stereo). And third, you will need yet another adapter to get the steering whell controls to work, if you have them.
Regarding the GPS, no you cannot use the sirius antenna, the units should come with their own. I have my GPS antenna sitting under the dash center speaker hole, works great and keeps it out of sight.
Thanks Vic,
I do have the Infinity speakers. By bypassing the amp, will I notice a change in the sound from the speakers?
About what should the installation and that harness run me?
IDK about the cost of installation, as i did my own, but the here's the hardware.
http://www.crutchfield.com/p_127SWIP...arch=pac&ssi=0
http://www.crutchfield.com/p_127C2RC...arch=pac&ssi=0
http://www.crutchfield.com/p_1207065...r+bypass&ssi=0
Pac adapter = $130
Steering wheel adapter (optional) = $75
Amp Bypass = $30
I put in JVC's high end GPS, and i actually think the sound quality went down. Mostly because the factory amp puts out, and also has internal frequency cross overs and such matched to the speakers. However, i plan on changing all the factory speakers as well.
Pac adapter = $130
Amp Bypass = $30
Gurr... I don't know squat about stereos to try and mess with all that. I don't want my quality to go down, but I don't want to spend a furtune on getting extra crap to make it work either. I may just leave it alone and stick with what I got.
Festus
21
Jan 28, 2009 10:04 PM
ptgarcia
Jan 4, 2007 06:14 PM
TxDiesel007
Sep 9, 2006 07:37 PM
