Steering shaft
Should there be any play where the pin is in hole in knuckle.
https://cimg8.ibsrv.net/gimg/www.die...6051a52879.jpg |
Mine did and some guys on the Cummins Forum site sourced some nylon bushings that tap into that space eliminating the slop. You then tighten a hose clamp around the area to keep them from wiggling out. I'll try and find the article. They can be had at Graingers with the right part #.
Thanks
Originally Posted by Danderson
(Post 3330197)
No I sure haven't. I'll try again.
Well,no luck. I do have a couple I can spare. PM me your address and I'l mail you a couple.
If you would, please give the dimensions of the nylon bushings.
With that info should be able to source them at either Grainger or McMaster Carr. |
Bushings
The bushings I saw and read about were nothing more than 3/8 ID nylon tube , sourced at local Ace Hardware . Cut to proper length and install a hose clamp or large cable tie to keep them installed in place . Pretty simple fix that works
Simple (and cheap) is great. Thanks.
