Steering overhaul... Need thoughts
So I am pushing 230,000 miles on the old girl and the steering shows it. granted they haven't been easy miles, she is used as my adventure rig.
So with that, my steering has started to become very hard at slow speeds and making a noise under the dash that goes away when I slightly turn the wheel or touch the brakes. Think I have heard this is the pressure line from the pump to the steering box that has failed internally?
While I was digging around I have also notice the box is leaking and has a lot of play, it has wandered for awhile now, and I have the old style steering that is pretty worn out...
Thinking of ordering the following:
Redhead rebuilt steering box
high pressure line
08.5 upgrade steering linkage kit
new pitman arm
bilsien stabilizer
Any thoughts on these parts? This hose going to fix the noise?
Thanks!
high pressure line
new pitman arm
bilsien stabilizer
Thanks!
also, is this the most current part number for the steering linkage?
52122362AH
Found the best price here...
52122362AH Mopar Dodge Ram Steering Upgrade $256.45
This the right kit?
52122362AH
This the right kit?
really? nothing?
Well thanks... This site really got me into these trucks and pushing the limits... used to recommend this site to a lot of people...
got more help on an expo site that doesn't specialize in dodges at all...
way to go "resource"
A quick search would've shown you that's the correct part number....https://www.google.com/search?q=5212...ckresource.com
Add ball joints and track bar to that list.
Why get so pissy? You do realize this is a quiet site, right? 10 years ago it was the cat's ****. There are 10+ years of posts to search....you couldn't find anything relating to your issues to give you confidence to buy the part to try to fix the issue? Here's the search that brings up threads that confirm what you are experiencing: https://www.google.com/#q=high+press...ckresource.com
Behold! ......The latest release part number is 52122362AL. The kits are available at AllMoparparts.com in 4 variations:
Kit Complete - Ram 2500 3500 Mopar Steering Upgrade Kit 52122362AL Complete (Part No: RAMSTKIT-COMPLETE)
Kit without pitman arm for those running lifts - Ram 2500 3500 Mopar Steering Upgrade Kit 52122362AL W/O Pitman Arm (Part No: RAMSTKIT-NO_PITMAN)
Kit without stabilizer for those who plan to run a high performance one - Ram 2500 3500 Mopar Steering Upgrade Kit 52122362AL W/O Stabilizer (Part No: RAMSTKIT-NO_STABIL)
Kit without both stabilizer and pitman arm - Ram 2500 3500 Mopar Steering Upgrade Kit 52122362AL W/O Both (Part No: RAMSTKIT-NO_BOTH)
few years ago everyone was having issues with the 08.5 steering upgrade, so I wanted to check. Few years ago everyone thought the borgsen box was great, and that has shown to not be great.
not really pissy, just disappointed in what used to be one of my favorite sites.
Track bar already done (carli) and ball joints as well (xrf) but might switch to carli when I get under there and inspect everything.
Thanks for the help.
I have been told to switch to the new mopar pitman arm to help the new linkage angles. with up to a 3" lift. (I have carli 2.5" coils) so I should update the pitman arm correct?
Thanks! It actually has held up very well. I have been pleasantly surprised, I did add a few more c-clamps for good measure, but so far so good with the heavy spare, 10 gallons of extra fuel, highlift and other equipment. I had to redesign the rack mounts to lower it down about 2.5" and that really helped with the top heavy feel and wind resistance...
Correct! I have a Carli system in my 03 including coils and new late model Mopar steering box. I used the new pitman arm as recommended by George at 8 Lug Truck Gear.
so got to looking through my records and I looks like 2 years ago I replaced this PS line once already. I thought it was a different one but looks like its the one...
The old one was leaking, and that makes me wonder if the previous owner or the dealer removed the liner out of it causing the leak? The new one was a Mopar OEM replacement and is making the noise that everyone seems to get. the old line never did...
Thoughts?
Anyone had any problems with the gates brand replacement?
Thoughts?
Grow up and use the Search Engine like a man and quit whining like a kid
Not sure my post warranted being called names, especially from a moderator, but oh well...
Back on topic, has anyone had issues with the Gates PS hose, or is OEM the way to go?
Bitching because you don't get fast enough answers don't help your cause any. This is better than calling tech support and getting Betty in Russia.
You can use a -6 an line and fittings. You have to find a way to support it though
