reverse lights stay on, wont shut off
Old 05-30-2011, 06:18 PM
freshmeat's Avatar
On my 2004 cummins I noticed that the reverse lights wont shut off, even when it isnt running and the key is off. I didnt do any kind of wiring or anything. All the wiring is all stock. Any ideas, for now I took the bulbs out so my battery wouldnt go dead.
Old 05-30-2011, 07:57 PM
DodgeChallenger's Avatar
You have probably shut the engine off in reverse and left the key in the ignition. If you do that in mine thye stay on until you remove the key from the ignition. Hope this helps
Old 05-30-2011, 08:19 PM
freshmeat's Avatar
Well I can try that but I dont think thats the problem. I took it for a drive today and the lights stayed on the whole trip.
Old 05-31-2011, 01:38 AM
sr4440's Avatar
power is provided to the backup switch (manual) or the transmission range sensor (auto) either one could be "stuck" on.
if you have a manual, i would pull the plug and see if the lights go out.
Joe
Old 05-31-2011, 08:20 PM
freshmeat's Avatar
I did that, I pulled the plug off of the sensor on the transmission and the lights stayed on. I can shut the truck off and remove the key and they are still on. Its a manual transmission.
Old 06-01-2011, 05:33 PM
DTR Detective
steelblitzkrieg's Avatar
Sorry if late, but is your cargo light turned on? I've accidentally bumped the cargo light and thought it was the reverse lights staying on, but then I noticed the over the bed light was also on.
Old 06-01-2011, 08:45 PM
freshmeat's Avatar
I checked that also, I am going to do some more messing around with it this weekend when I have more time.
Old 06-01-2011, 10:16 PM
torquefan's Avatar
I would take apart the trailer connector and have a look inside it. Sounds like a wire may have come off in there and is jumping power from the 12v wire to the reverse light wire.
I can't see the reverse light switch being shorted because that circuit should only be powered with the key on.
Old 06-02-2011, 05:47 PM
freshmeat's Avatar
Thanks for the idea, I will give it a try.
Old 07-12-2018, 09:21 PM
Rudy Villasenor's Avatar
Reverse light staying on
Did you ever figure out why your reverse lights are staying on I'm having the same problem in my 07 Dodge 2500 diesel
cjs1450
01-13-2014 03:57 AM
dkimmel
01-03-2011 10:54 PM
nvr-enuf
02-16-2010 12:58 PM
randyswelding
02-09-2009 10:40 PM
Jim Dynomite
06-06-2006 09:57 PM
Quick Reply: reverse lights stay on, wont shut off
