replace seat belt
Need to replace drivers side seat belt and retractor assy. Electrical connector on the retractor belt tensioner assy does not come off easily. Don't want to screw it up. Is there a trick to removing it or is there a special tool for it.
Thanks Mike B |
I dont know how to replace them. I have been trying to figure out where I read about a warning about being careful when messing with them.
This is all I could find. 3.1.5 SEAT BELT TENSIONER Front seat belt systems incorporate Tensioner Modules (SBT). At the onset of an impact event each tensioner uses a pyrotechnic device, which is triggered simultaneously with the airbags, to rapidly retract the seat belts. With the slack removed, the occupant’s forward motion in an impact will be reduced as will the likelihood of contacting interior components. After an impact that deploys the airbag, the seat belt tensioner assembly must be replaced. TheACM module monitors the Seat Belt Tensioners circuit resistance and reports active and stored DTC’s if any problem is found. |
