Reading a dip stick
06 With 48 Re.there Are Three Marks On The Dip Stick One Says Min.an The Other Says Max. Then The Next One Says When Hot.does When Hot Mean Normal Operating Tempature Or Does It Mean When Its Hotter Than Normal.sorry For Such A Stupid Question.
I am no dodge genius but usually "hot" means operating temp.
when the trans fluid is @170* it is fully expanded and that would be considered "hot" if you don't have a trans gauge then I would say go by engine op temp...
53 is right. The book says you need to drive it about 15 miles to get the trans temp "hot" (180 degrees). I have a trans temp gauge, and I haven't been able to get mine above 150 yet. You really do have to drive it awhile before the trans fluid gets hot . . . these trucks have such a big cooler on them. You also need to check it with the engine running.
Ive Been Changing Oil Pans Lately And Paying Atention To The Dip Stick .i Do Watch The Temp Guage Just Trying To Figure Out If I Have The Right Amount Of Fluid. Thanks Guys
hmmm... I messed up. When I saw the subject matter, I thought it was a class on how to understand weird people. Sorry!
My tranny gauge has only hit 140* once if I am lucky. Most of the time it is around 100* all the time. I have a JC Whitney LED gauge and the sending unit is in the Hot line that I got from Mass Diesel.
Even when I had a normal tranny Temp gauge, it only read about 120*, maybe, if I was lucky. I don't tow or haul anything, just a normal driving dodge that likes to do burnouts now and then. But I can't believe it runs so cool. I even hear the tranny shift into OD on cold morning long before the gauge starts reading at 70* and I think OD won't shift until it is at least 70*. Thought about trying to get another sending unit but am afraid that it would be the same readings. |
Originally Posted by FirstDodge
(Post 1414414)
Yet another reason not to have the out of park alarm recall done! Does the stupid alarm at least stop when you close the door after exiting the vehicle? Or do they expect you to check the transmission fluid level with the horn blaring about three feet away? What committee of lawyers and bean counters came with this one!?
Originally Posted by Nuttymopar
(Post 1415402)
nuttymopar- those temps seem real low-especially for winter time in vermont! i am in ny. i just moved my probe from the port on the side of the tranny where you get cooler temp readings-which were still higher than your temps! i installed the tranny line you have on saturday. sunday, the temps around here were in the 20's. i took the old lady for a drive and saw tranny temps has high as 160 degrees in mixed driving!!!!.
| All times are GMT -5. The time now is 02:21 AM. |
