Rail Pressure Sensor
Old 04-04-2014, 11:37 AM
bullrambler's Avatar
Greetings all
I did the normal removal of Fuel rail Valve cover removal to do the test on injectors. My Rail Pressure Sensor came off in two pieces. The plastic (black) top piece seperated from the metal housing that screws into the rail. Is this normal or is the Rail Pressure sensor a two piece unit...? There are no cracks and the pieces fit back together. Your comments are appreciated.
Old 04-08-2014, 07:53 PM
It's a bosch sensor and bosch told me to replace it. They also said to try it and see if it will work. I'll have a new one on hand in the event that it doesn't work.
Old 04-08-2014, 08:37 PM
TolyM's Avatar
It should be one piece.
I would replace it.
Sent from my VS980 4G using Tapatalk 2
Old 04-09-2014, 06:11 AM
Thanks TolyM I am having a new one sent over today. If it's not here today it will arrive tomorrow.
Old 04-14-2014, 05:55 PM
Changed out to the new pressure rail sensor, and truck fired up with two new reman injectors, and a new valve cover wiring harness.
Old 04-14-2014, 06:05 PM
TolyM's Avatar
Glad you got it fixed.
I got 6 reman injectors. Had them for over 20k miles without an issue.
Friend of mine has remans for over 100k miles with great filtration has no issues.
Old Smoky
0
08-10-2011 02:53 PM
dodgediesel
11-25-2010 07:40 PM
5.9Excursion
03-13-2008 10:56 AM
bluebull
03-13-2007 07:29 PM
Quick Reply: Rail Pressure Sensor
