Programming key fobs...anyone know how?
I just bought a 04 3500 and it only had 1 key fob with it so the dealer gave me a key fob from another 04 dodge truck and I was wondering if I could program it to my truck or is that a dealer issue?
Welcome Aboard!
The procedure is on page 21 of my owners manual. Its probably in your OM too. |
Do the batteries in these fobs ever have to be replaced? Are they likely to leave us srtanded one of these days? Since the truck will not run when started with a conventional key I'm a little concerned.
Wetspirit |
Originally posted by Wetspirit Do the batteries in these fobs ever have to be replaced? Are they likely to leave us srtanded one of these days? Since the truck will not run when started with a conventional key I'm a little concerned. Wetspirit |
SuperGewl
[duhhh] Eeeek, what was I thinking? Thanks, Wetspirit |
From the 2004 shop manual:
The following procedure can be used as long as one programmed transmitter is available: NOTE: When entering program mode using that programmed fob, ALL currently programmed fobs will be erased and they will have to be reprogrammed for the vehicle. If program mode is entered and no action is performed, the previously programmed fobs will continue to function. (1) Enter the vehicle and close all doors. (2) Fasten the seat belt (this will cancel the seat belt chime). Turn the ignition to the RUN position. (3) Press and hold the UNLOCK button on a programmed transmitter for 4 to 10 seconds. Within the 4 to 10 seconds with the UNLOCK button still depressed, press the PANIC button for one second. When a single chime is heard, release both buttons. The chime indicates the system is in program mode. (4) Press and release both the LOCK and UNLOCK buttons simultaneously on a fob to be programmed. A single chime will be heard, this indicates the fob has been recognized. (5) Press and release any button on the same fob. A single chime will be heard, this indicates the fob has been programmed. (6) Repeat steps 4 and 5 for up to a total of 4 fobs. (7) Turn the ignition OFF. (8) Turn the ignition ON or wait 60 seconds. The vehicle will remain in program mode for up to 60 seconds from when the original chime (step 3) was heard. After 60 seconds, all programmed transmitters will function normally. |
Since we're on the subject, here is how to replace the batteries:
The Remote Keyless Entry (RKE) transmitter case snaps open and shut for battery access. To replace the RKE transmitter batteries: (1) Using a thin coin, gently pry at the notch in the center seam of the RKE transmitter case halves near the key ring until the two halves unsnap. Be careful not to damage the rubber gasket when separating the case halves. (2) Lift the back half of the transmitter case off of the RKE transmitter. (3) Remove the two batteries from the RKE transmitter. (4) Replace the two batteries with new 3V lithium 2016 cell. Install the batteries with the positive terminal up. Reference the “+ SIDE UP” on the inside of the bottom half of the transmitter case. (5) Align the two RKE transmitter case halves with each other, and squeeze them firmly and evenly together until they snap back into place. Test transmitter operation. |
Unless i'm right out to lunch, the key fob he's talking about is not the key with the electronics in it , but rather the little black hand held unit that lock and unlocks the doors.
But if there isn't already one programmed keyfob, does it need to be taken to the dealer? I got the Mopar keyless entry for Christmas and am pretty sure that is what I need to do after installing it.
Nick |
Thanks for all the input.......After I posted this thread I thought......I bet it is in my owners manual.....duh.
This is a cool site...I know it will be alot of help in the future..... |
Nirion,
You'll have to post the instructions that came with that Mopar keyless entry (to get an answer out of me anyway). If the Mopar keyless entry is like an aftermarket keyless entry then no you won't have to go to the dealer. It's probably a self-contained unit. Even if it is the same as the factory installed unit, you probably won't have to take it in because the transmitters that came with your unit are probably already programmed for that unit. But again, that's all a guess since I haven't read the instructions. |
