Overhead Computer/Mirror won't work in cold weather
Old Dec 10, 2013 | 03:23 PM
ripster's Avatar
The overhead trip computer, outside temp display and auto dimming mirror quit working in cold weather. It has been this way for a couple of years with it getting steadily worse, until this year where it quit working in anything below 50 degree weather. I "heard" this was a common problem, but did not find anything when I searched. Any suggestions? Easy repair or take to dealer?
Old Dec 10, 2013 | 11:09 PM
BigIron70's Avatar
Cummins Guru
Perform a COMPASS MINI-TRIP COMPUTER self test.
If the problem with the compass mini-trip computer is an inaccurate or scrambled display, refer to SELF- DIAGNOSTIC TEST. If the problem with the compass mini-trip computer is incorrect Vacuum Fluorescent Display (VFD) dimming levels, use a scan tool and the proper Diagnostic Procedures Information to test for the correct dimming message inputs being received from the Body Control Module (BCM) or Front Control Module (FCM) over the Programmable Communications Interface (PCI) data bus circuit. If the problem is a no-display condition, use the following procedure.
For complete circuit diagrams, refer to the appropriate wiring information. The wiring information includes wiring diagrams, proper wire and connector repair procedures, details of wire harness routing and retention, connector pin-out information and location views for the various wire harness connectors, splices and grounds.
1.Remove the overhead console from the headliner (Refer to 8 - ELECTRICAL/OVERHEAD CONSOLE - REMOVAL).
2.Check for battery voltage at the overhead console electrical connector. If OK, go to Step 3. If not OK, Check for battery voltage at the appropriate B(+) fuse in the Integrated Power Module (IPM), repair the open fused B(+) circuit as required.
3.Turn the ignition switch to the On position. Check the fused ignition switch output circuit(s) at the overhead console electrical connector. If OK, go to Step 4. If not OK, repair the open or shorted circuit as required.
4.Turn the ignition switch to the Off position. Disconnect and isolate the battery negative cable. Check for continuity between the ground circuit cavity of the overhead console electrical connector and a good ground. There should be continuity. If OK, refer to SELF- DIAGNOSTIC TEST for further diagnosis of the Electronic Overhead Module and the PCI data bus circuit. If not OK, repair the open ground circuit as required.
A self-diagnostic test is used to determine that the EOM is operating properly electrically. Initiate the self-diagnostic test as follows:
NOTE: The compass mini-trip computer self - test can also be performed using a scan tool. Refer to Auto Self Test under the System Tests.
1.With the ignition switch in the Off position, simultaneously depress and hold the STEP and RESET buttons while rotating the ignition switch to the Run/On position.
2.Continue to hold both buttons depressed until the EOM enters the display segment test. In this test, all of the Vacuum Fluorescent Display (VFD) segments are lighted while the EOM performs the following checks:
◦Non-Volatile Memory Status (NVM)
◦RAM Status
◦ROM Status
◦ASIC Communication Test Status
◦Compass Test Status
◦DC Status
◦PCI data bus Communications Test
NOTE: If module is equipped with the Universal Transmitter, the module also checks “Universal Transmitter Communication Test Status”
3.Following completion of these tests, the compass mini-trip computer will display one of two messages: “FAIL” or “PASS.” Press RESET or STEP to exit and enter normal mode. Respond to these test results as follows:
◦If no test result message is displayed, but compass mini-trip computer operation is still improper, the use of a scan tool and the proper Diagnostic Procedures Information are required for further diagnosis.
◦If the “FAIL” message is displayed, the EOM is inoperative and must be replaced.
◦If the “PASS” message is displayed, the EOM is OK, no faults are present.
◦If any VFD segment does not light during the display segment test, the EOM is inoperative and must be replaced.
4.If the first seven tests pass, the compass mini-trip computer shall verify that all the required PCI bus messages are present on the PCI bus. If all required messages are present on the PCI bus, or if the ignition switch is turned to the Off position, the EOM will automatically return to normal operation. The required PCI bus messages are:
◦Dimming message
◦Fuel Used message
◦Distance Pulses message
◦Percentage Fuel Tank Full message
◦Fuel Type message
◦VIN (Vehicle Identification Number)
◦Vehicle Speed message
◦Last Engine Off Duration message
◦Ambient Air Temperature message
NOTE: The Fuel Used message shall be ignored if the engine type is Diesel or Compressed Natural Gas.
NOTE: Pressing the STEP or RESET switches during any portion of the testing procedure will cause the compass mini-trip computer to exit diagnostics and return to compass/temperature mode.
NOTE: If the compass functions, but accuracy is suspect, it may be necessary to perform a variation adjustment. This procedure allows the compass unit to accommodate variations in the earth's magnetic field strength, based on geographic location.
NOTE: If the compass reading has blanked out, and only “CAL” appears in the display, demagnetizing may be necessary to remove excessive residual magnetic fields from the vehicle.
Old Dec 11, 2013 | 11:32 AM
ripster's Avatar
Thank you!
Old Dec 11, 2013 | 01:11 PM
SOhappy's Avatar
Another reason I'm liking my ST, less stuff like that to go bad.
Old Dec 11, 2013 | 01:35 PM
Numidian's Avatar
At least we get to enjoy them while they work. And it's certainly not hurting anything sitting up there blank
DogRam
Sep 21, 2012 08:57 PM
royta
Feb 28, 2010 09:32 PM
Dodge Mack
Oct 12, 2009 05:38 PM
nugirlintexas02
Jul 28, 2007 05:33 PM
crobtex
Dec 23, 2004 07:52 PM
