-   3rd Generation Ram - Non Drivetrain - All Years (https://www.dieseltruckresource.com/forums/3rd-generation-ram-non-drivetrain-all-years-101/)
-   -   New Toyo Tires Sound Out Of Balance (https://www.dieseltruckresource.com/forums/3rd-generation-ram-non-drivetrain-all-years-101/new-toyo-tires-sound-out-balance-271810/)
bansh-eman Jun 15, 2010 10:47 PM
Ok so I took my truck, had it realigned, and had the tires rebalanced. The guy said however balanced my tires the first time did them wrong. He was able to get them to balance to 0 on all 4. When going do the road it gives off that sounds like the tires are out of balance, rather than a constant hum from bigger tires.
Does anyone else have this issue?
Fisherguy Jun 16, 2010 08:26 AM
Haven't hit any curbs lately? Bent axle or something?
Toyo's usually don't take much weight to balance, it the steering wheel shakes that's an indicator of front tires not balanced, if the whole truck shakes it's probly the rears.
bansh-eman Jun 16, 2010 09:17 AM
Nope no curbs or heavy offroading. I take it fairly ez on my truck. The truck doesn't shake at all, it just has the sound like when a tire is out of balance.
larrybartlett Jun 16, 2010 09:27 AM
might be the road and not the tires?
bansh-eman Jun 16, 2010 10:18 AM
The only reason I think it isn't the road is I hear it on several different kinds of pavement
wanna2500 Jun 17, 2010 02:13 PM
Did you have them rotated at the same time? If you did, the wear pattern now running in a different position will make that noise. If so, it will quiet down after you put some miles on them.
bansh-eman Jun 17, 2010 06:41 PM
YEs they have been balanced twice all at the same time. I need to give them a look over to see that they are all facing the same direction.
1985cucv Jun 17, 2010 06:44 PM
baneshman i used the air soft pellet trick in my 305's which are 33's and the thing rides awesome. idk if you want to try it let me know i can help you out its amazing i wasnt a believer until i tried it. ididnt want weights on my new powdercoated rims
bansh-eman Jun 17, 2010 07:15 PM
Did you get the bags or are they free floating beads?
Where did you get them?
