New Toyo Tires Sound Out Of Balance
Old Jun 15, 2010 | 10:47 PM
bansh-eman's Avatar
Ok so I took my truck, had it realigned, and had the tires rebalanced. The guy said however balanced my tires the first time did them wrong. He was able to get them to balance to 0 on all 4. When going do the road it gives off that sounds like the tires are out of balance, rather than a constant hum from bigger tires.
Does anyone else have this issue?
Old Jun 16, 2010 | 08:26 AM
Fisherguy's Avatar
Haven't hit any curbs lately? Bent axle or something?
Toyo's usually don't take much weight to balance, it the steering wheel shakes that's an indicator of front tires not balanced, if the whole truck shakes it's probly the rears.
Old Jun 16, 2010 | 09:17 AM
bansh-eman's Avatar
Nope no curbs or heavy offroading. I take it fairly ez on my truck. The truck doesn't shake at all, it just has the sound like when a tire is out of balance.
Old Jun 16, 2010 | 09:27 AM
larrybartlett's Avatar
might be the road and not the tires?
Old Jun 16, 2010 | 10:18 AM
bansh-eman's Avatar
The only reason I think it isn't the road is I hear it on several different kinds of pavement
Old Jun 17, 2010 | 02:13 PM
wanna2500's Avatar
Did you have them rotated at the same time? If you did, the wear pattern now running in a different position will make that noise. If so, it will quiet down after you put some miles on them.
Old Jun 17, 2010 | 06:41 PM
bansh-eman's Avatar
YEs they have been balanced twice all at the same time. I need to give them a look over to see that they are all facing the same direction.
Old Jun 17, 2010 | 06:44 PM
1985cucv's Avatar
baneshman i used the air soft pellet trick in my 305's which are 33's and the thing rides awesome. idk if you want to try it let me know i can help you out its amazing i wasnt a believer until i tried it. ididnt want weights on my new powdercoated rims
Old Jun 17, 2010 | 07:15 PM
bansh-eman's Avatar
Did you get the bags or are they free floating beads?
Where did you get them?
Syndicate
Jan 10, 2008 05:21 PM
wreedCTD
May 9, 2007 05:29 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
wallypedal
Jan 30, 2006 05:46 PM
Bobcat698
Sep 19, 2005 06:53 PM
