modified fuel canister
Old Nov 15, 2009 | 10:22 AM
turbo hoss's Avatar
does anyone make a ready to drop in modified fuel canister that replaces the cheap plastic fuel connections with something better? I would realy like something with threded supply and return lines. I seem to have to drop the tank once a year for some reason or anouther and hate how the foul lines connect to the module (pain in the but). Maybe a larger supply line eliminate fuel restriction. I know there are drwy straw kits but would realy like something that is drop in ready and all I would have to do is modify the fuel supply and return lines to fit the new canister.
Thanks
Old Nov 15, 2009 | 05:49 PM
turbo hoss's Avatar
perhaps someone can tell me where to find a cheap stock replacement 2004 fuel module so that I can fab up what I am wanting.
Old Nov 15, 2009 | 11:26 PM
Fisherguy's Avatar
Try putting a wanted ad in the classifieds.
You hook your Fass to the stock canister?
Old Nov 15, 2009 | 11:34 PM
Fisherguy's Avatar
(Part of this message EDITED,.....Non-DTR Advertiser)
Last edited by John_P; Nov 17, 2009 at 06:01 AM. Reason: Advertising, Non-DTR Advertiser
Old Nov 15, 2009 | 11:59 PM
annabelle's Avatar
Have you thought of using a Hellman sump?
Old Nov 16, 2009 | 04:27 PM
MikeyT's Avatar
Airdog II comes with a new, modified fuel module. I think I'm going to go with that setup.
Old Nov 16, 2009 | 11:07 PM
Fisherguy's Avatar
You there Hoss?
Old Nov 17, 2009 | 08:16 AM
turbo hoss's Avatar
yea I am here just had a busy day yesterday. Does any one know the size of the doorman connector on the return line on the fuel canister?
Old Nov 17, 2009 | 08:30 AM
Fisherguy's Avatar
My 06 was 3/8".
Any place that sells them should be able to tell you what size for your year.
Old Nov 17, 2009 | 08:34 AM
BarryG's Avatar
You might try checking with Vulcan Performance
http://www.vulcanperformance.com/Dra...w-p/jlfmds.htm
They have a drop in modified unit. If it is not what you are looking for you might give them a call they also have the various parts to modify your own if I recall.
Also I think the return line dorman fitting is 5/16 on the stock module. The supply line on mine was 3/8.
Well at least on my 01 the return was 5/16 sounds like it may be different on the later years
turbomike
Jun 23, 2010 10:56 AM
jsmith2260
Apr 25, 2010 02:32 PM
The_Head
Dec 26, 2008 07:49 AM
Wes in TN
Dec 30, 2005 11:01 AM
steveb
Aug 20, 2004 12:48 AM
