| Tecnology |
Jul 20, 2025 10:56 PM |
LED Taillight Wiring
Hello all. I have an '06 Ram 1500 and I've put a flat bed on it that uses the same type of taillights as a TJ Wrangler, the three stud kind. They're LED and I've wired in 6 ohm, 50 watt resistors into the stop/turn circuit. Now both rear turn signals hyper flash, and both sides come on, along with the third brake light flashing, no matter which direction I'm signaling. Should I get higher wattage resistors? Or would this be solved with another fix? Thank you in advance
