Inalfa Factory? Sunroof Issue
Anyone have, of have worked with an Inalfa Sunroof? I have one that I THINK was a dealer installed unit in my 05 Ram 2500 CTD Laramie. It's a model "ASI 925 FF". Please note that one feature of this unit is that whatever position the glass is in, it will close once the key is turned off.
I'm having an issue where the "close" position isn't closed...the back of the glass is slightly depressed. I did the "initialization" procedure to reset it to factory settings, and then shut the key off. The roof closes to where it should. But then I'll go back out to the truck a little later, the the back of the glass is depressed again. I run the re-init, turn it off, it closes, then be driving down the road and hear wind noise...it's cracked again. I don't see anything in my manual but a initialization procedure. I sent an email to the manufacturer but I'm not sure what kind of help I'll get as it was installed 4/05. Any thoughts? Thanks in advance! |
Fixed!!
Problem solved. The place that installed the sunroof is pretty local. I went over Monday after work, and the guy I spoke to actually installed the sunroof originally. Turns out it was a screw that worked loose and fell out, allowing the sunroof to drop. He hooked me up for next to nothing! Auto Sun Roof in the Delaware/NJ Area...I highly recommend them!!
